      12-03-2010, 11:11 AM   #1
Boosted_N54
Boosted_N54's Avatar
180
Drives: 135i N54
Need HELP on winter tire setup
i need some help on choosing winter tires for my 135i 08 stock rims does anybody know what are my best option for
a winter setup on my stock rims NO RUN FLATS please..
will this SIZE of tire rub? 215/45/18 Front & 245/40/18 Rear
http://www.tirerack.com/tires/tires....+240+Sottozero
      12-03-2010, 12:16 PM   #2
zoidberg128
Drives: 2010 128i
Nokian Hakkapeliitta + 2 100lb bags of sand in the trunk. Iv been ripping though Buffalo snow all week.
      12-03-2010, 01:46 PM   #3
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
Give me a call. I'd be happy to talk over the options with you.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      12-04-2010, 04:56 PM   #4
bet
Drives: 135i
As you have likely discovered there are no non-RFT winter tires in the stock sizes. The fronts you mention are .4 inches taller and 3.4% slower on the speedo (assuming accurate and there is additional info on that issue) where speedo will show 60 when actual speed is 62.1mph. The rears you mention are .5 inches taller and 3.9% slow. I too have been investigating this same issue.
The common solution utilizing the stock wheels seems to be a "square" set up utilizing 225/40-18 on both the front and rear. The size difference is only .1 inches and 1.4% difference on the speedo. Using this set up there are multiple choices from Bridgestone, Dunlop, Michelin and Pirelli.
I am leaning towards the Michelin PA3 with this square set up.
      12-04-2010, 11:59 PM   #5
Boosted_N54
180
Drives: 135i N54
those tires look interesting is 225/40-18 good for all around will they be any rubbing? what do u think of the ones i was 1st talking about?
      12-05-2010, 01:41 AM   #6
bluebimmer135
Drives: 2009 Motego Blue 135i Coupe
Just did mine with Alpine Pilot PA3 225/40/18 for the front and 235/40/18 for the rear, did not want to do the square since planning to use the tires for the next car when my lease ends in 2012. Anyway, so far so good, comparing to the stock Bridgestone RFT, better traction, smoother ride with better shock absorption. the car seems accelerates faster, seems to be the best choice for the winter here in north jersey. garage told me that my stock tires are pretty worn after about 18k miles, which i was surprised at first then not so much after finding out a lot of people worn out theirs after only a year. In short, the stock RFT's suckness is now confirmed comparing with the PA3, highly recommend if not expecting to drive in deep snow.
      12-05-2010, 01:53 PM   #7
bet
Drives: 135i
On a stock suspension there should be no issues with rubbing at all with 225/40-18. I am sorry I can't help you with the tires. I too, have been looking for information on Pirelli winter tires. Unfortunately it seems most opinions are of the older compounds and tread design.
      12-05-2010, 02:18 PM   #8
Boosted_N54
180
Drives: 135i N54
so you put non RFT 225/40/18 FRONT and 235/40/18 REAR
PA3 Alpine Pilot on stock susspension and you didint have any rubbing?
1addicts
