11-27-2010, 12:43 AM | #1 |
20
Rep 111
aero bumper on M Coupe
okay first off, please dont give me the "omg dont put that on your M, that will take away from the authenticity blah blah blah.." i truly believe to each his own, and with my deployment currently in afghanistan, i know that when i return i want to have my M have its own uniqueness.
understanding that the aerodynamics bumper was never officially offered for the M Coupe/Roaster, and knowing that its not a direct plug & play, i'm seeking the help of other aero bumper swaps, and people who could offer insight. im basically looking to complete the aerodynamics front bumper and side sills. having a 05/2006 build M Coupe, i would like to retain the headlight washer feature, but hopefully not have the front reflectors integrated. Also, I will modify the foglight openings to act as a brake duct from the M bumper. based off realOEM.com, a E85 Z4 3.0si Aerodynamics package as my guide: http://www.realoem.com/bmw/showparts...29&hg=51&fg=95 I figure I would need (or like) to order the following components. -Front bumper trim with all required screws and mounting hardware -Front bumper grills -Front bumper tow hook cover -Front bumper undertray and hardware -New front wheelwells lining -Aero bumper side sills and hardware (which has been done on Z4M's) Gathering from the realOEM.com chart, I'm just hoping I can get some help with identifying all necessary part numbers needed. Any prior Aero Bumper owners, please chime in. Thanks in advance. |
11-27-2010, 01:08 AM | #2 |
Engineer
216
Rep 2,122
Drives: M235I 2015, 335i 2011
Go for, I'm doing the same thing. It should fit fine with some small adjust on the under tray, nothing that could not be handle. I'm a fan of that bumper as well and I can't wait until I'm done.
11-27-2010, 01:09 AM | #3 |
Engineer
216
Rep 2,122
don't buy the under tray, your under tray will fit just fine.
11-27-2010, 01:11 AM | #4 |
Engineer
216
Rep 2,122
No need for wheelwells yours will do just fine as well and the brake ducts will fit just some cuts on the front.
11-27-2010, 02:44 AM | #5 | |
20
Rep 111
glad to know the undertray and wheel linings will fit.. small adjustments or modification to existing trays or lining shouldnt be an issue. |
11-27-2010, 07:27 AM | #6 |
20
Rep 111
okay, based off this link to realOEM.com here are the parts listed i think i'll need for the front bumper and side sills.
NO. DESCRIPTION QTY PART NUMBER 02 PRIMED FRONT APRON (W/ HEADLIGHT WASHERS) 1 51110149439 03 DOOR SILL COVER, PRIMED RIGHT 1 51710150780 03 DOOR SILL COVER, PRIMED LEFT 1 51710150781 06 BODY NUT 3 07129904220 07 FILLISTER HEAD SELF-TAPPING SCREW 3 07119904220 09 CLIP 14 51717055847 10 EXPANDING RIVET 16 51118174185 11 BODY NUT 2 07129904150 12 GASKET LEFT 2 51717125691 12 GASKET RIGHT 2 51717125692 14 GRID, CENTER 1 51130151008 15 GRID LATERAL LEFT 1 51130151050 15 GRID LATERAL RIGHT 1 51130151051 19 BODY NUT 8 07129901646 20 FILLISTER HEAD SELF TAPPING SCREW 8 07119901168 21 FLAP, TOWING EYE, PRIMED 1 51117056922 Again, I believe this to be for builds 01/2006 on, so I would assume this to fit my 06. Again, this should have the headlight washer, and I will modify the foglight opening to act as a brake duct in some way. If any aero bumper owners can provide input on my parts lists, I'd greatly appreciate it. Thanks. |
11-27-2010, 11:42 AM | #8 |
23
Rep 1,034
I ordered the entire Aero kit for my '04 The only major difference I can think of for pre/post facelift and the kit in general is the fog lights and rear apron. The kit didn't even come with a cover for the tow hook, I had to reuse the one I had.
The grills are the same on all Z4 models
Straightaways are for fast cars, Corners are for fast drivers.
12-10-2010, 10:10 AM | #10 |
20
Rep 111
12-12-2010, 02:49 PM | #13 |
'Entwicklung 85 - Zukunft4'
26
Rep 238
I am as much as excited to see this Aero Kit on his MCoupe. The bumper & side skirts have already arrived, just waiting for a few small parts. Once everything is in, I will be taking his car to the shop for the retrofit.
As my son has said, the retrofit should be completed before the end of this month. As soon as it is done, I will take a few pics and post them, including a few shots next to dad's car , for a visual comparo. |
12-12-2010, 05:38 PM | #14 | |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
father/son on zpost, very cool |
12-13-2010, 03:17 PM | #15 |
Rep 174
I'm wondering whether the foglight openings will do for the brake vents. The vents are large and have pretty beefy scoops on the M bumper, and the brakes still seem to get rather hot. Any thoughts on this?
12-13-2010, 03:35 PM | #16 | |
John 14:6
59
Rep 588
What's next?
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
12-13-2010, 04:19 PM | #17 |
Mouper
114
Rep 1,064
Same, but I think the fogs more "direct" position at the front of the bumper will more air to pass through from sheer speed. Maybe an air splitter could be mounted inside to divide the flow around to the brakes?
12-13-2010, 04:23 PM | #18 |
Engineer
216
Rep 2,122
^No, You should have less air coming in because of the design, that is the reason I will be using other ways to direct extra air to the brakes as well from the lower vents.
12-13-2010, 06:25 PM | #19 |
23
Rep 1,034
'stock' the vents on the outside of the aero bumper are actually covered, while the center portion is a plastic mesh vent. Not that it wouldn't be easy to do something else with it.
edit: parts 15 in the picture
12-13-2010, 06:46 PM | #20 |
55
Rep 1,224
You'll be one of the first as I'm sure we'll be over there to work on the M. Remember, work first then beer.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
12-13-2010, 06:53 PM | #21 |
Engineer
216
Rep 2,122
Yes I know, the m3 people have the same problem but you can research what they did and that is kind what I'm going for, anyways I will try to find something and post here later.
12-31-2010, 05:00 PM | #22 |
26
Rep 238
I went to see the car yesterday for my son, and it looks very nice, not too mention it is very unique sort of like a special edition model
The overall appearance, especially on a black coupe is most definitive and impressive, and the visual lines flow with the car. The Aero Bumper on the M Coupe does not look aftermarket or tacky at all (e.g. taken lines from other BMW models, such as E46 or E90, etc.). It does not look like an expensive name-brand add-on either, it's OEM, and the fitment is perfect. and in my opinion it still maintains the heritage of still being a pure M, regardless. My taking & posting pictures will be an understatement and an injustice. I have no photo skills either... I will be picking up the car and bringing it home on Monday, along with other goodies that I have been instructed to pick up. |
