11-10-2010, 05:24 PM | #1 |
24
Rep 416
Crazy Rattling noise
The crazy clutch rattaling noise when I engage and stop start the car doesn't have anything to do with the Engine mounting bolts that ive been reading about does it?
11-10-2010, 05:47 PM | #2 |
Rep 199
I had a very bad rattle/knock at one point when I would press all the way down on the clutch about a year ago. Turned out to be the throw out bearing. Just fyi.
SSG S |
11-10-2010, 07:23 PM | #3 |
42
Rep 632
I concur, seems likely, especially if there are no problems with the shifter going into different gears.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
11-10-2010, 08:21 PM | #4 |
Bad Lieutenant
233
Rep 3,517
Dual mass flywheel?
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
11-10-2010, 08:32 PM | #5 |
1154
Rep 1,543
For the OP, from what you very briefly described, I don't think it's related to the engine mount bolt issue. If it were, you should be able to notice something 'different' even at idle.
- Jeff
bosstones' flickr |
11-10-2010, 09:05 PM | #6 |
Imola Lover
26
Rep 749
If this is occuring only when slowing down and disengaging the clutch when the engine is still under load, and you get a quick, successive, cha-cha-cha-cha-cha chatter, then it's the dual mass flyweel and it's a normal sound.
11-12-2010, 12:56 PM | #7 |
44
Rep 1,855
Man, you've just made me feel a lot better about the sounds I've been hearing from my car.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
11-12-2010, 02:31 PM | #8 |
24
Rep 416
After I googled and read more about dual mass fly wheel, i think it is the springs making the noise. The noise only comes from nuetral to first and from first to neutral at really slow speeds.
11-12-2010, 08:18 PM | #9 |
1144
Rep 2,872
Drives: Anything
I'm also hearing this chatter when disengaging the clutch going from 1st to 2nd gear...is this also the dual mass flywheel that's making the noise?
01-15-2011, 09:16 PM | #10 |
485
Rep 10,309
Drives: A///MERICAN!!!
01-15-2011, 10:46 PM | #11 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
clutch chatter is normal in these cars. i complained to my service advisor and they replaced the whole clutch pointing to a damaged flywheel. 1 month later, the sound reappeared (although it was not as loud, but present nonetheless).
01-18-2011, 11:04 PM | #12 |
29
Rep 518
hey guy might be wrong but i also hear that noise on my car, but my car is auto and is not m only hear it when the car is slowing down or slow speed any suggestion?? my car warranty is almost over 5 more moths to go.. any advice?? what needs to be replace??
01-19-2011, 07:41 AM | #13 |
485
Rep 10,309
If you're under warranty schedule an appointment. Arrange for a loaner, because if they end up needing to drop the tranny it'll probably be at least a couple days...hell they would keep my 335 for 2 days just to change the microfilter
