ZPOST
  TireRack
      01-28-2007, 05:04 PM   #1
Artz 330
196
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
Arrow Launching in 2nd gear
Well, Yes I guess you can say I was a little bored. The other night I was thinking about this for a while. So I decided to try it today. Turned on my Navi and reset all the timers. It was mighty cold and a bit damp today.
First 3 Launches I did 0-60 at 2,500 RPM with minimal spin and was able to get 4.5 Seconds each time. in 1st gear
Well than I tried 2nd gear.
1st Try : 5,000 RPM took off and slightly let off the gas way too much due to wheel spin and got 5.6 seconds to 60.
2nd Try : Tought that I was spinging too much and brough it down to 4,000 RPM, less wheel spin but seemed to bogg out slightly before it hit higher RPMS result was 5.1 to 60.
3rd Try : I went up to 5,300 RPM and let it go it finally hooked at 30MPH and the result was insane 4.3 Seconds
4Th and finaly : 6000 RPM let it go spun a millisecond cause I played with the accel and it hooked right away. Final result was 4.0 seconds Flat. Totaly got rid of the 1-2 shift. It was insane.
I did this with the navi unit and its pretty accurate. I wanna set up the Gtech in the car and get a vid.
Well thanks for reading my pointless thread
      01-28-2007, 05:08 PM   #2
Greeney
Greeney's Avatar
213
Drives: Jerez E90 M3
How did you do it? Just started and stopped the timer when you went?
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 |
      01-28-2007, 05:11 PM   #3
Jaws
Jaws's Avatar
45
Drives: 2006 325i mt
How is this relate to E9Xs in any way?
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red
2007 Chev Silverado crew cab Z71
      01-28-2007, 05:13 PM   #4
Artz 330
196
2006 330i  [0.00]
right before i hit 60 on the navi screen it has a stop and start time. and it has the MPH on the same page, right before i hit 60 i looked down on the navi it said 60 and it had the seconds right next to it, so right at 60 thats what the time was. but after 60 the clock kept going...
      01-30-2007, 03:01 AM   #5
nyc3r
nyc3r's Avatar
112
Drives: E90
speedo is off a little though.
      02-01-2007, 03:58 PM   #6
Artz 330
196
2006 330i  [0.00]
it said 60 on the navi which is 63-64 on speedo
      02-05-2007, 11:44 AM   #7
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Did you have DSC on or off?
      02-06-2007, 10:37 PM   #8
fastJ
Drives: 06' M Z4
can you explain a little how u used the nav to time your 0-60? can you do the 1/4 mile also.
      06-28-2014, 04:43 PM   #9
NavZ
South Africa
Drives: '09 E86 Z4M Coupe
Necro post but has anyone else tried this?
      07-17-2014, 03:44 AM   #10
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Never tried launching in 2nd before... sounds like it will cause premature wear on drivetrain specifically the engine, tranny, and clutch.
Especially at 4k rpm.
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      07-17-2014, 04:25 AM   #11
tikamak
Lebanon
58
Drives: 2006 Z4M Roadster TiAG/black
Well you can hit 3.8 if you rev more, but that means you can do it 3-4 times before it costs you a drivetrain. at least a clutch.
This car is not very efficient at dragging, hence why they put a 4.35 ratio in it to make up for it and have comparable 0-60 times to the cayman S.
However it really excels on the track.
You can check @gmd2003 's supercharged car with some suspension and brake work running with super cars and humiliating them on the track.
      09-12-2014, 10:12 PM   #12
RossBMWZseries
226
Drives: '11 E92 328i LCI & '06 Z4MR
Wait...you guys are talking about a stock Z4M here??? I've tested it myself (RDSport exhaust, RPI scoop) and my fastest time was 4.7s 0-60. Keep in mind, that our reaction time to start/stop the timer is critical. I bought an app for my phone and it starts the timer as soon as your car moves forward from a standstill., my worst time was 5.6 seconds.
4.5, 4.3, 4.0, and 3.8 sounds impossible. Then again, I don't know that because I've never launched in 2nd gear
      09-16-2014, 07:54 AM   #13
Aries326
Aries326's Avatar
195
Drives: 2008 Z4 3.0si, 2013 E92 M3 ZCP
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
What app did you get to time your 0-60?
      09-16-2014, 09:58 PM   #14
RossBMWZseries
226
It's called dynolicious. Haven't used it in a while, but it uses your GPS and Bluetooth for accuracy. IIRC, it was about $10. It allows you to enter the weight of the car, tank size, how many gallons of gas you have in the tank while running, passengers, cargo. 0-60 times and more depending on what you want you just set it up. Also has a skip pad, not sure if it's all accurate though.
zpost
