10-28-2010, 05:00 PM | #1 |
1015
Rep 1,721
Z4M = 32MPG
Usually I can nurse 24MPG out of my Z4M on the highway, can't really average much better than that over a long stretch.
So the other day, just for fun, I put 110 octane fuel in my ESS tuned Z4M. I've put 110 octane in before when it was stock and it made no difference at all but this time I averaged 32MPG at 70MPH over 10 miles with cruise control on. Now obviously I don't care about average MPG on the Z4M but without a dyno, these numbers really show just how much more efficient the engine can be with higher octane and a proper tune. Great work ESS
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
10-28-2010, 05:08 PM | #2 |
111
Rep 1,351
Drives: in Anger.
Was that downhill with a tailwind?
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
10-28-2010, 05:15 PM | #4 |
218
Rep 4,726
That's weird, 110 octane actually has less energy then 93, it's good for making power but it shouldn't have really boosted efficiency. Octanes not necessary at low load cruising conditions.
10-28-2010, 06:21 PM | #6 |
12
Rep 725
10-28-2010, 07:28 PM | #7 |
2434
Rep 11,668
A 10 mile run is not a big enough sample to determine accurate mileage.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
10-28-2010, 08:17 PM | #8 | |
Rep 238
And, by the way, octane works by making gasoline burn slower and at a higher temperature. Not necessarily with less energy. I can easily see the efficiency increase because gas mileage is related to spark advance. The more spark advance you can run at any given throttle opening the better the gas mileage will be. So, with 110 octane, knock is mitigated and the knock sensors will allow more spark advance than would ever be possible with 93 octane. The end result should be increase gas mileage. Whether 32 mpg is achievable in an S54 I can't say. With 110 octane, the gas is most probably 100% gasoline with no ethanol. Just that difference alone would increase gas mileage. Theoretically and based on only available energy a vehicle that gets 24 mpg on pure gas will only get around 23 on gas with 10% ethanol. |
10-28-2010, 08:44 PM | #9 | |
218
Rep 4,726
Also 110 octane absolutely contains less energy then 93.
10-29-2010, 01:42 PM | #10 |
Car Geek
3697
Rep 3,616
+1 ^
The other factor is that the most efficient engine map is usually aimed at the "recommended" octane for the vehicle. Fall back to a map with less advance across the range is used when knock is detected while using lower octane fuel, besides a bit of variance with different fuels and from vehicle to vehicle, using a higher octane fuel than recommended isn't going to do a lot, unless a remap of the ECU to user higher octane fuel has been done. |
11-01-2010, 03:54 PM | #12 |
1015
Rep 1,721
The racing fuel that I used was ethanol free and ECU was tuned by ESS for 93 octane. I don't know much about how all this works, maybe the headers and intake helped as well. In any case, I encourage others with an ESS tune to try it out and post if you're getting around the same MPG at 70MPH with cruise control over some flat distance.
11-03-2010, 04:33 PM | #13 |
My favorite sign.
169
Rep 4,333
How about I post my non-tune efficiency with 98 octane (euro) at 160 on the speedo?
11-03-2010, 07:56 PM | #14 |
NewFinishColumbia/detailer
604
Rep 2,096
That would be awesome. I'm hoping to be able to test that myself in a couple of years.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
Tags |
ess |
