BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      06-15-2010, 02:26 PM   #1
New_m3
20
Drives: E92 M3
Can i run tires with a lower load rating?
I’m interested in getting a set of Bridgestone potenza RE050A, however they have a load rating of 94. The stock Michelin ps2's have a load rating of 98.
Does anyone know what the difference is, or how it will affect the car?
      06-17-2010, 12:47 PM   #2
New_m3
20
Drives: E92 M3
hmm, anyone?
      06-17-2010, 03:06 PM   #3
R A W L S
R A W L S
R A W L S's Avatar
17
Drives: 1997 M3
2008 M3  [0.00]
I'm no expert but I've noticed heavier load rating tires don't roll as much in cornering during track events as lower load rating tires. During daily driving I haven't noticed much difference between lower and higher ratings. I would check that 94 meets bmw recommended standards.
      06-17-2010, 03:29 PM   #4
ben@tirerack
M3Post Supporting Vendor
87
Drives: 740i
Yes, it is ok to do. 94 load index tires carry maximum 1477 lbs per tire, supporting rear gross axle weight up to 2954 lbs (that's rear axle only, not whole vehicle).
For handling reasons, I would not recommend mixing tires. If you put something different on the rear, you should put the same brand and style of tire on the front too. If you only replace two, stick with the same tire that is on the front.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
m3post
