03-08-2010, 08:15 PM | #1 |
240
Rep 462
anyone with 225F and 255R on OEM 18" rims and lowered?
Just wondering, how many of you with 135i's are running 225/40/18 front and 255/35/18 rear on the OEM 18" wheels and are lowered, either with the BMW Performance suspension, or something else with a more significant drop?
I know this wheel/tire set-up works for the stock height, but I want to know if I'll encounter any rubbing if I run this set-up on a lowered 135i. Thanks in advance. |
03-09-2010, 08:58 PM | #3 |
325
Rep 1,804
There's my front set up...
Eibach Springs 225/40/18 Hankooks Stock Wheels 12mm Spacers ...NO rubbing. Tight as you can go on stock wheels. If I was lower I'd go with a 10mm spacer. I have 245 rears so there's obviously no rubbing. You should be fine.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-03-2010, 12:08 PM | #4 |
Navy Chief
31
Rep 447
Drives: '14 CBM X6M
running on h&r sport springs, stock rims, and yoko s-drives. with that tire setup. I dont think I have any rubbing
04-03-2010, 12:44 PM | #5 | |
Ex '87 Carrera
248
Rep 1,259
Not to thread hijack or anything... ianc |
04-04-2010, 11:32 PM | #6 | |
325
Rep 1,804
I really like the Eibachs now. I was kinda regretting getting them when I had the RFTs on, but now that I have non-RFTs I love the set up. The drop is near perfect (the rear could be a tad lower) and the ride isn't too harsh.
-Nick
04-04-2010, 11:41 PM | #7 |
Ex '87 Carrera
248
Rep 1,259
Thanks for the input. I Had Hankooks on my 911 and loved them, so I'll probably go with them when the RFT's die. They are definitely priced right...
What are you running for shocks? ianc |
04-05-2010, 04:11 AM | #9 |
Rep 58
My front set up is:
PSS10 coilovers with Vorshlag strut tops (just over 1 inch drop) M3 lower wish bones 2 deg negative camber 10mm wheel spacers 225/40/18 I have no rubbing
135i Sport | Black Saphire Metalic | Boston Black | 6speed | 10 Speaker Hifi | Sunroof
04-05-2010, 05:08 PM | #10 |
325
Rep 1,804
Stock shocks right now. I'll probably get coilovers in the next year. I just NEEDED the car lower now.
-Nick
04-05-2010, 07:24 PM | #11 |
ElevenPointFive
327
Rep 2,450
Thanks for this thread I am contemplating the same issue as the OP. I am runnning hankook v12 225/40/18 and 255/35/18 on my 261 rims. I want to go to the H&R Sport Springs for the agressive raked look but was curious if there was going to be rubbing. Sounds like I will have no issue, thanks guys and cheers to the OP.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
04-05-2010, 07:36 PM | #12 | |
168
Rep 773
I'm running these exact sizes with Dunlop Star Specs and a Performance suspension.
No rubbing except when i bottom out or something. Jeff Quote:
04-07-2010, 01:31 PM | #13 |
Rep 9
im running 225 front and 255 back on performance wheels with performance suspension and i've had no rubbing whatsoever, even with a fully loaded car with luggage.
shawn |
