03-02-2010, 04:48 PM | #1 |
Lead, follow, or get the hell out of my way
32
Rep 429
widest wheels and tires on 135?
without looking retarded and ruining the ride. any ideas?
2010 X3
2013 RS5 |
03-02-2010, 04:54 PM | #2 |
53
Rep 754
Evolution racewerks has 285's in the rear but Im not sure how much modifications they did. The also run 285 in front but the run their wide body conversion in the front.
03-02-2010, 05:33 PM | #3 |
10
Rep 446
Wrong section, but do a search in the wheels/tires section.
Quick answer is generally that you can fit 225F/255R tires with most 1 series fitment wheels (assuming 18x8"F and 18x9"R). APEX makes some 18x8.5"F and 18x9.5"R wheels with offsets that will allow you to do more, with perhaps as much as 285s in the rear with little to no modification and 255s in front with some Vorshlag camber plates. I'm waiting to put them on myself. Fronts are always the toughest to get wide tires without some modifications because you don't have a lot of room to play with. |
03-02-2010, 05:50 PM | #5 |
aka 1013MM
1266
Rep 9,545
i run 235 and 255 I could have had 265 in the back but I was rubbing all 4 corners anyway lol minor roll or negative chamber can fix.
03-03-2010, 08:19 AM | #6 | |
Auto X'er
Rep 157
Hope this helps...
2009 135i SGM, Premium, Sports, Nav.
Dinan Stage 2 software, Injen intake, RR Oil Catch Can, H&R Pro-coilovers and springs, H&R front sway bar, Vorshlag camber plates, Vorshlag comp studs, BMW strut brace, BMW performance pedals, G-Force harneses, BMP tow hooks, Breyton GTS-R wheels with 255-35R18 (square set up) and custom axel back exhaust with muffler delete. |
03-05-2010, 04:16 PM | #7 | |
Rep 222
AW/BL'ette/Sport/Cold/CA/IpodUSB
[SIGPIC][/SIGPIC] |
