01-29-2010, 05:49 PM | #1 |
Chirurgeon
39
Rep 424
Cracking headlight plastic
Hey guys
noticed tiny little cracks in both my front headlights, numerous almost horisontal cracks almost like multiple stone chips. I suspect its from heating/cooling of the plastic from running the lights on all the time anyone else has the same problem? Cheers
E Pluribus Unum
02-01-2010, 02:54 AM | #2 |
24
Rep 895
If you suspect it's caused by the xenons, you should take it to your dealer for a warranty repair.
08 BMW 135i Sport Coupe | Manual | Sparkling Graphite | Coral Red Boston Leather | 10 Speaker Hi Fi
02-01-2010, 04:42 AM | #3 |
135 to 335 M Sport to X3 30d M Sport
164
Rep 1,788
Drives: 2018 X3 30d, optioned up!
I have the xenons and use the daytime running lights and, for a change, don't see the problem.
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
02-01-2010, 04:42 AM | #4 |
44
Rep 1,883
As I understand it... Xenons should be cooler than halogens as much more of their 35W power goes to creating light rather than heat. Halogens 55/60W bulbs are less efficient and hotter.
02-01-2010, 06:24 AM | #5 |
Chirurgeon
39
Rep 424
Dunno, the dude who owned the car for 4 months before I bought it put aftermarket blue/white headlights in them. Not even sure of the brand but they whiter and brighter than the stock yellowish ones
E Pluribus Unum
02-01-2010, 06:33 AM | #6 | |
Lord Captain Commander
110
Rep 3,093
Not a problem within itself (other than the fact that they usually emit less light than the standard yellowish white) but if he went for some el cheapo ones off the internet, then the glass on the bulb might not have a UV filter. That unfiltered light high in UV might be what's causing damage to the headlight plastic. If you want to claim under warranty, I suggest you replace them with stock bulbs before you take it into the dealer.
E82 135i M-sport: SGM/6MT/Black |
02-02-2010, 01:07 AM | #9 | ||
110
Rep 3,093
A high power halogen bulb within 5cm emits many many times more UV than is possible to receive from the sun. That's why the glass on the bulb (which is immune to the deteriorating effects of UV unlike plastic) should contain a filter in order to protect the lens cover. OP, get those bulbs out before they do further damage! If the cracks you are talking about are hairline width, then it definitely sounds like UV deterioration.
E82 135i M-sport: SGM/6MT/Black Last edited by Jeef Beef; 02-02-2010 at 01:17 AM.. |
02-02-2010, 06:22 AM | #11 |
Disillusioned bourgeois capitalist pig!
21
Rep 488
Wouldn't putting in high drain halogens throw a code. I thought the halogens ran different voltages and draw than xenon. Any sparkies want to comment?
You can lead a fool to knowledge but you cannot make him think!
02-02-2010, 06:35 AM | #12 |
110
Rep 3,093
dr.bmw does not have the xenon option for his 125i, so his headlights are halogen. As long as the replacement halogens are also 55W/12V, no code will be thrown. Blue-look halogens usually have a filament that burns at a higher temperature and/or a blue filter on the glass.
