01-15-2010, 03:22 AM | #1 |
29
Rep 246
8.5x19 et35, 10x19 et38 ..wil it fit a 135i coupe?
i ordered some wheels for my e92 coupe
Front-- 19x8.5 5x120 +35 offset Rear-- 19x10 5x120 +38 offset will they also fit a 135 series coupe with stock suspension or even lowered? |
01-15-2010, 08:13 AM | #4 |
2148
Rep 10,176
Absolutely less-than-zero chance of those rears fitting the 1 series. Sorry. They'll be sticking past the fenders by more than an inch. The fronts would likely work with a 225 on it .
01-15-2010, 09:07 AM | #5 |
154
Rep 4,528
Drives: M2 CS
i dont really see the rears fitting, you'll prob need at least -4deg of camber
im all bout the hella flush but this might be too much, if you pull it off, ill def be interested in pics since these are for your e92, why do you wanna know if they'll fit a e92? just incase you wanna sell them down the line? |
01-15-2010, 11:39 AM | #6 |
29
Rep 246
ok good to know, they fit the e92 perfectly even when lowered. i just wanted to know cause a friend wanted the same rims to fit on his 135 coupe.
02-03-2011, 10:28 PM | #9 |
aka 1013MM
1266
Rep 9,545
mine are 18 and a little bit more aggressive in the front with 8.5 you can do it with stretched tires like me no probs.
im around 2.5" lowered. no neg camber. rolled and pulled fenders all around.
