      10-16-2009, 03:27 PM   #1
135ARG
135ARG's Avatar
Drives: 2009 BMW 135i
Question mixing RFT(front) and regular tires(back)
After 9000 miles the RFT rear are nearly dead, I'm planing on getting the Yokohama S.drives. The wear in the fronts seam to be alright, so here's my question.
Should I get the rear Yokohama and keep the RFT in the front, or just get all 4?
Discount tire is having a $100 rebate so i would almost be getting the two fronts for the price of one, which complicates the decision.
I would appreciate everyone's opinion in this decision...
Thanks
      10-16-2009, 04:56 PM   #2
RPM90
890
Drives: 340i M-sport AT
Thanks
Not too complicated, ALL 4 tires should be the same.
      10-16-2009, 05:27 PM   #3
Tom K.
Tom K.'s Avatar
124
Drives: '07 328iT, '13 Boxster
As I'll be getting about 24,000 miles out of the OEM rear tires on my 128i and double that on the front, my plan is to replace the rears with the OEM RFTs and then go for non run-flats when all 4 need replacing. But with only 9k, you might want to crunch the numbers on this option compared to 4 new tires. Either way, I'd avoid having different F/R tires on the car, especially run-flats & non RFTs.
Tom
      10-16-2009, 05:39 PM   #4
Feyd
Feyd's Avatar
348
Drives: a DEEZZULL
Don't mix tires. Its not a good thing...
      10-16-2009, 06:06 PM   #5
SPEZNAS92
Drives: 2009 135i
Get four Yokohama tires and either store (if leased) the RFT's.... or sell them if your buying the car.
RFT's
      10-16-2009, 06:55 PM   #6
WhiteOne
28
Drives: 2008 AW 135i
Have you read the Car and Driver test report?
Hankook V12 > S Drives and cost less too!
      10-17-2009, 07:50 PM   #7
135ARG
135ARG's Avatar
why do all 4 tires have to be the same? can't think of any reason except just being picky. i drove with different rear and fronts in my m3 and had no problems with it.
any technical reason?
      10-17-2009, 07:56 PM   #8
jibaholic101
160
Drives: women wild
the tires will have different wear patterns and tread patterns.
it just effects handling is all, and is bad in performance applications
get all 4
some italian, german, and japanese ones; and on order more of the same
      10-17-2009, 09:41 PM   #9
135ARG
135ARG's Avatar
i just dont want to throw away 2 perfectly good tires
      10-18-2009, 12:48 PM   #10
esses
esses's Avatar
No_Country
19
Drives: like I stole it.
You aren't throwing away two perfectly good tires. You are throwing away two stock run flat tires.
If you are just driving around you probably wont see much of a difference. If you push it, my guess is you will see major understeer and increased body roll/flex. RFTs have stiff sidewalls and not much transfer between traction and sideways - real tires are stickier and will transition. I know guys who put r compound slicks on the back of their daily drivers at the dragstrip with regular rubber up front - but they are not turning.
      10-18-2009, 01:06 PM   #11
jibaholic101
160
Drives: women wild
you can sell the two tires here under the for sale section, there are always people buying spare tires
      10-18-2009, 04:52 PM   #12
jkp1187
Unindicted co-conspirator
66
Drives: to work, mostly.
Until yesterday, I would have disasgreed with esses. But yesterday, I put on my 17" snow tires (Blizzaks).
The ride is almost night-and-day difference -- and remember, these are snow tires, which usually ride a little harsh anyway. But it is so smooth over bumps now, I almost don't want to go back to the RFTs in the summer.
Heck, you want to buy four RFTs, that way you want have to throw away any?
      10-18-2009, 11:28 PM   #13
cagekicker
cagekicker's Avatar
16
Drives: '09 crimson red 135i
i gotta agree with you.
6MT/ Sport Package/ N54/ Asa wheels/ Eibach pro kit springs/ Active autowerke Exhaust/ 35% tint
      10-21-2009, 11:28 AM   #14
ManGGouste
35
Drives: 125i
I tried to mix RFT front with regular rear...
Don't do that, man, that's simply horrible.
The balance of the car will be completly affected.
I changed my rear RFT after one got blown with 2 regular Falken FK-452 (same size of course).
Here's what I've experienced :
-car oscillating on highways : the rear of the car is always slightly going left & right so that you're correcting with the steering wheel all the time. Very tiring on long trips. And dangerous when it's windy.
- unpleasant oversteer (also due to the fact that these Falken are a bit narrower and they stick less on dry ground) in all curves. Note that I usually like oversteer.
-I even had the ESP braking some wheels on long curves on the highway (although I was driving at legal speeds !)
So I've bought some new front tires right after but I'm waiting to mount them at the same time as my Quaife LSD in a few days.
      10-23-2009, 09:21 PM   #15
135ARG
135ARG's Avatar
this is intresting.. has anyone else experience simillar problems?
135i Coupe sport with: JB4, BMW Performance Exhaust, Cross Drill/Perforated front rotors, Black Kidney Grills, Carbon Mirrors, Carbon Tail, Carbon Diffuser.
      10-23-2009, 11:55 PM   #16
Berduderunner
drk one
Berduderunner's Avatar
38
Drives: 2008 135i
2008 e90 335i  [0.00]
2008 135i  [0.00]
I replaced my stock rears w. Star Spec Z1's and kept the RFT's in front for another 8000k. Not the best for handling, but I had no issues at all (and I drive like a jackass)
Jet Black | Coral | HighGlossBlack | Steptronic | Premium | Sport | Comfort | ActiveSteering | Navi | HiFi | HD | iPod | SAT
BMS JB3 v2.0 | BMS DCI | Berk Tech Sport Exhaust | UR * DPs | CoolingMist Meth Kit w/ CMGS | H&R OE Sport Springs | Breyton GTS-R | Dunlop Direzza Sport Z1 Star Specs | GP Thunder 8000K Low Beams/Angel Eyes/Cornering Lights | LED Interior Light Kit | Window Tint | Smoked Tail Lights | Smoked License Plate Cover
      10-24-2009, 06:20 AM   #17
ptack
ptack's Avatar
269
Drives: 135i
2008 135i  [6.50]
It all depends on how you drive. If you're going to be a little old lady you may be fine. If you at all try to drive the car aggressively you could be rudely surprised, Unless someone else has already tried mixing these same tires and can report on it, there's no way of predicting how it will work. Tires having their own tread patterns, shapes and compounds. There are too many variables to say if/when they can be mixed.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
      10-26-2009, 07:44 AM   #18
imported_mega
No_Country
123
Drives: various bmw's
as long as front are paired, and rear are paired your fine, hell our cars are offset already
I would ditch those runflats fast though
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      10-27-2009, 03:17 AM   #19
ManGGouste
35
Drives: 125i
I forgot to mention once my rear tires get a little used, they seem to get harder so that the difference is less noticeable.
This is also probably due to the fact that the garage used some kind of grease to put on the tires, so that it would move slightly on the wheel.
At the beginig, the difference was huge : hard tires at the front, marschmallow at the rear.
Allthough it's better know I can't wait to get rid of thoses front RFT.
      10-28-2009, 04:09 AM   #20
135ARG
135ARG's Avatar
decided on getting the 4 new tire... thanks everyone for the feedback, i truly appreciate it.
on that note anyone want my front RFT?
1addicts
