09-07-2009, 08:51 PM | #1 |
Rep 10
Dinan Stage 1 & Camber Plates
After much research and actually purchasing H&R springs from Turner Motorsport (to be returned), I've finally come to the conclusion that Dinan's package is my preferred set-up. The question I have is how many other's with any of Dinan's set-up are running their camber plates? I realize that their plates only off-set the adjustment range but am wondering if I will need the shift for a car that will be driven mostly on the street?
Any insight is greatly appreciated... |
09-07-2009, 09:11 PM | #2 |
One mod leads to another ...
418
Rep 2,900
I have the Dinan springs without the camber plates. There is a fair amount of camber adjustability with the OEM setup so I do not think the camber plates are necessary especially if you are not tracking this car predominantly. You are making a good choice.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
09-07-2009, 09:20 PM | #3 |
Rep 10
Thanks!
Did you install yourself or have a dealer install? Do you notice the .5" drop at all? Would you say overall performance is improved? Sorry for all the questions, just want to make sure spending the xtra $ will be worth it. |
09-07-2009, 09:33 PM | #4 |
418
Rep 2,900
I installed them myself. I do notice the drop. I haven't pushed the car too hard on the street but it does feel more connected to the road. It is more firm than stock but not bone jarring. I usually ride around in comfort mode on the interstate, etc. Before with the stock suspension it could feel skittish at speed over broken pavement in a turn. That is no longer an issue with the Dinan system.
09-07-2009, 10:12 PM | #5 |
Moderator
673
Rep 4,737
With a 0.5" drop, your camber would already go more negative than before. Unless you track your car, there is absolutely no need for camber plates for the street.
I am getting my Dinan springs tomorrow too. |
09-07-2009, 10:16 PM | #6 |
684
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
I agree, you don't need the camber plates for a primarily street driven car. If you go to agressive on your camber settings your tires will vanish quicker, your car will tram on uneven surfaces more, etc.... That's why I decided against the plates.
09-07-2009, 10:56 PM | #7 |
72
Rep 1,803
The springs WILL adjust camber by themselves.
Are the camber plates easily removable? I would like to be able to take them off when I switch my track wheels/tires back to street.
[SIGPIC][/SIGPIC]
2007 GT3 Clubsport w/CGT buckets in Scotland 2003 CSL, SG, Alcon BBK SOLD 2002 M5, SSII/Blk and bone stock. In storage back home in TX 2008 M3, AW/Blk 6MT, lots of track stuff SOLD |
09-08-2009, 12:03 AM | #8 |
248
Rep 6,125
FYI,
Dinan spring + camber plates will sit slightly higher than normal dinan's minimal drop. So it'll be very very slight drop. But most of Dinan spring owners don't care for much drop. =)
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
09-08-2009, 11:20 AM | #10 |
248
Rep 6,125
Right way to start- congrat!
09-08-2009, 04:07 PM | #11 |
172
Rep 676
sway bar
Why not the stage 2 with the sway bar? I got it and LOVE it-quite flat and just holds that line in curves-of course I did not drive stage 1 so cannot compare.
09-08-2009, 05:05 PM | #12 |
Rep 82
for those who installed the dinan set up, did you remove the locater pins in the upper strut mount before you aligned it?
I put in on the rack and it swept out at -1.4 (L) and -1.1 (r) camber.....pretty much in the dinan specs that they included in the spring kit. Is camber adjustable at all with the pin in place? looks like the pin would pretty much prevent any movement of the struts within the slotted holes...so no adjustment, this sound about right?? Caster was a little high, but thats not adjustable anyways and was even side to side.....set the toe to .05 each side for total of .1 total toe (front)......seems to work |
10-19-2009, 07:30 PM | #13 |
Rep 10
Installation / Alignment Complete
Completed the install about a week ago...extremely straight forward. I was even surprised that my spring compressors fit the front coil springs with no major issues (have had to do some crazy things in the past to be able to compress the spring enough before achieving coil bind on the compressor...that probably won't make any sense to anyone but me...oh well).
I did not remove the locating pins on the supplied "camber" plates...and honestly don't think that removing the pins would gain you much adjustment. That is just my opinion based on the clearance noted on the "camber" plate studs / nuts. I could be wrong there...Dinan states in the instructions that it is possible and I'm sure they know what they are talking about...just don't expect to get a ton of adjustment. I must say the car drives like a dream!!! I never would have expected to state that not only do I feel like the car handles better but the overall ride quality is improved as well.......and it closes the fender gap that had me wondering if I purchased a rally car. It does not slam tires / wheels into the fenders but, it does visually improve the stance. I am 100% satisfied...and am so happy I didn't go with the H&R springs I originally purchased. On a side note, the bump stops and "camber" plates Dinan provides with their kit are BMW parts that are found on a different car...if you search this forum someone else posted the details. Too bad you can't just purchase the Dinan springs because you probably could save yourself some money by purchasing the springs from them and the rest of the hardware from your BMW dealer...or possibly combine their researched "camber" plate & bump stop configuration with H&R, etc springs for a greater drop and increased wheel travel in the front. ....I digress |
