09-03-2009, 10:28 AM | #1 |
70
Rep 1,339
Wheel Alignment on E90 M3
I recently hit a pot-hole hard enough to require a wheel alignment for my 08 M3 Sedan. The BMW shop used generic specs for a 3 series to complete the alignment (attached). If there is an expert out there who can comment on whether this is appropriate, or if different "M3" specs should be used, I would appreciate the help. I have read conflicting comments on-line. (the handwritten notes on the left). The car is essentially for street use, so specific track specs are not necessary.
Thanks in advance for your help. |
09-03-2009, 05:16 PM | #3 |
2511
Rep 4,381
Wheel_Alignment_US.pdf
This is the USA spec for the E46 M3....probably not much use except for giving an idea of the general alignment for this type of sport suspension. |
09-04-2009, 09:37 PM | #4 |
310
Rep 2,189
Looks like the specs that you got are pretty good; little toe, even caster, even camber. Should be great for street driving... you have a touch of negative camber in the front (good) and a little more than that in the rear (also good). If you start adding extreme negative camber, you can wear your tires out faster and have suboptimal grip under braking.
09-05-2009, 04:26 AM | #5 |
2511
Rep 4,381
Instead I would suggest that the car a little needs more front negative camber....I'm betting that the proper specs for his car would show something similar to the E46 M3 spec...gives better turn in and better grip under heavy cornering load at the front with no downside under braking once the tyres have worn in to the new alignment.
09-05-2009, 06:43 AM | #6 | |
310
Rep 2,189
09-05-2009, 07:33 AM | #7 | |
2511
Rep 4,381
I guess so...myself I would make the trip back once the dealer has the correct M3 alignment spec if it varied significantly from the generic 3 series spec they used. |
