08-29-2009, 01:48 AM | #1 |
12
Rep 73
TPMS Sucks Caution !
My TPMS system on the M3 is messed !
I have HRE 890R wheels and you cannot get the senors to fit properly to utililize the valve stem on the sensor to inflate the tire with air. You must use a secondary mount inside the wheel in order for it to sit flush. The stem on the sensor cannot be accesed from the out side of the wheel. The problem I first had was my sensor on a front wheel got knocked off i I assume a pot hole caused this , my wheel shook like it was out off balance , but no TPMS malfunction light . I assumed the sensor was still working. Second accurance was the rear wheel , I had a rotational noise as if i had a nail in the tire that you could detect only at low speeds, by the time I checked it out I realized the sensor had been knocked off on the inside of the wheel , wheen i pulled back the tire the sensor was in peices destroyed !. I just removed it and never reinstalled a new one , I Never got a TPMS malfunction yet Last weekend my steering wheel started to shake , i assumed another sensor fell off on the front wheel sensor mounting again because I had the same symptoms as the first time , I was far from home so i continued to drive , when i got to the shop and took off the tire to check the wheel i found the tire was flat and the wheel was slightly bent , I had to replace the tire as it was ruined from the inside and get the wheel straightened . No TPMS error ever! Im driving now missing two sensors and the light still hast come on Anyone have any explanation for this ? My light be constantly on. One time I had a flat tire error , I checked the pressures and all was good , reset idrive and never came back Spoke to the dealer and they feel it has to do with the aftermarket wheels , but i havnt took it in yet . Should the dealer if the system is found not to be working reinburse my aftermarket tire at least I know I should have maybe checked my pressure when the wheel started to shake a bit but I was on a Highway close to Whistler Mountain Anyways any sujjestions or similar experiance would be helpfull . Cheers
08 M3 Coupe AW FR CF ROOF FULLY LOADED EDC
VORSTEINER FRONT LIP VORSTEINER, VORSTEINER REAR DIFFUSER H&R SPRINGS 20 INCH HRE 890R w EIESRMANN RACE EXHAUST, BLACKED OUT GRILLS , BLACKED OUT SIDE VENT, PAINTED REFLECTORS |
08-29-2009, 06:19 AM | #2 | |
818
Rep 7,887
08-29-2009, 07:58 AM | #3 |
27
Rep 1,314
Let me get this straight, you bought a set of after-market wheels that are incompatible with the OEM TPMS system, and you're blaming the system?
I've purchased HRE wheels before, and they very clearly provide info on their web page that some of their wheel designs are incompatible with some TPMS systems. Those designs can use an alternative mounting method which involves banding the sensor to the inside of the barrel, and it sounds like your installer did a bad job. I fail to see how "TPMS sucks" in your case. You didn't do your wheel selection homework properly, and it sounds as if your installer did a bad job of mounting the sensor. However, it sounds like your car is Canadian as noted by another poster above, and your car is equipped differently.
08-29-2009, 08:38 AM | #4 | |
206
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
08-29-2009, 10:13 AM | #5 |
893
Rep 9,034
I bought some TPMS from a Canadian dude who bought some wheels from a US dude. That should tel you something.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
09-08-2009, 08:50 PM | #6 | |
12
Rep 73
09-08-2009, 09:03 PM | #7 |
12
Rep 73
Im not blaming bmw or hre for my sensors falling off just the tires and how low profile they are, System still did not warn me of a flat tire even when it was low
09-10-2009, 03:33 PM | #8 |
76
Rep 649
If you have a Canadian car why do you have TPMS sensors installed?? We have a flat tire monitor instead, and do not need the sensors since our system uses the ABS and wheel rotation speed. Take the rest of your sensors out and have your wheels checked and balanced before re-mounting.
09-10-2009, 04:46 PM | #9 |
818
Rep 7,887
Did you reset as per the manual?I find it works quite well and has caught tires going down on our other vehicles well before they were flat.The lower profile the tire is,the less warning time you have.
