08-04-2009, 12:48 PM | #1 |
221
Rep 2,339
OEM battery connector
I know Technic has posted it before but I can't seem to find it. Where can you get this OEM connector to connect additional power wires to the battery through the OEM distribution block? Does it come in different sizes for larger cables? I'm hoping to install a 2 AWG wire for an amp but if not I'm sure I can get by with 4 AWG since the run is so short.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
08-04-2009, 01:19 PM | #2 |
2288
Rep 13,001
That OEM crimp connector is for 8 gauge and just borderline for 4 gauge, that's the reason I soldered my 4 gauge cable to it in addition to partially crimping it.
The OEM connectors and their respective housings (item 14 in single and double contacts) P/N are here: http://www.realoem.com/bmw/showparts...46&hg=61&fg=30 |
08-04-2009, 03:44 PM | #3 | |
221
Rep 2,339
08-04-2009, 04:40 PM | #4 | |
2288
Rep 13,001
I noticed that in my distribution block some of the empty slots did not have the metal tab to connect. The P/N are legit, just combine the 1-POL (single) or 2-POL (double) connector P/N to their respective housing P/N and order them thru your dealer or Tisher/United BMW online. |
08-16-2009, 12:56 AM | #5 | |
221
Rep 2,339
08-17-2009, 07:57 AM | #6 | |
2288
Rep 13,001
That will tell you which slot has a live tab (or two tabs). |
08-17-2009, 12:23 PM | #7 |
221
Rep 2,339
Crap. I hate when the simple answer is overlooked! Thanks for the tip
08-19-2009, 02:44 AM | #8 |
221
Rep 2,339
Checked it this afternoon. Looks like only one slot is live So much for my idea of running 2 sets of 8 AWG. Looks like my only choice is to squeeze a 4 AWG in that 8 AWG connector too.
09-03-2009, 12:32 PM | #9 |
221
Rep 2,339
Just checking out this picture, I'm wondering how the OEM distribution block is connected to the battery.
At first I was thinking its a bus tie but looking at the picture it looks like cable #6 might be the one feeding the distribution block. If that's the case, that's only a 4 AWG and with all the other connections made on that block it might not be enough to support the existing loads and the added load from my amp.
09-03-2009, 12:40 PM | #10 | |
2288
Rep 13,001
09-03-2009, 12:57 PM | #11 |
221
Rep 2,339
I bought a Zapco DC 650.6 which has an 80A fuse and 4 AWG is rated for 85A. I know I will probably never get close to actually drawing 80A and like you said, the cable runs are short so voltage drop is not really an issue but I wasn't sure what the other loads on that block were so I was a little concerned. You're running a PDX 4.100 and 1.600 from that block right. I assume that the draw on those two amps are probably similar or even higher than my DC 650.6 so I've you've never noticed any electrical issues than I'm sure I'll be fine too.
09-03-2009, 01:14 PM | #12 | |
2288
Rep 13,001
I got a 4.150 (60A fuse) and a 4.100 (50A fuse) and I like to listen to music a lot with the car off, and so far no issues... but I use a battery tender at least every other weekend to keep the battery from premature crapulation. |
