07-23-2009, 04:55 AM | #1 |
BMW Freshman
Rep 82
Dynamant Weight and Performance
I am interested, or at least currently researching, the use of dynamat in the E90 to both reduce road noise and improve sound quality. I'm not sure what placement and where would be best, but say that it was a near full install. About how much weight would that add? Has anyone worked with this?
This car will probably be 95% street and 5% track. Edit: Dynamat Extreme is what I was considering, due to decreased weight and, well, obviously increased performance. |
07-23-2009, 07:14 AM | #3 | |
74
Rep 610
I agree, even with an x-pipe its not that loud.
EDC.....viagra for your car
07-23-2009, 08:16 PM | #4 |
286
Rep 6,007
In my opinion part of the fun of the M3 is the decreased sound deadening materials you find in more luxury type cars. This is supposed to be a sports car you want to hear all the noises.
07-23-2009, 08:32 PM | #5 | |
BMW Freshman
Rep 82
And I just realized I spelled Dynamat wrong... somehow. |
07-24-2009, 05:17 AM | #6 | |
221
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
07-24-2009, 06:37 AM | #7 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I would do the areas near the speakers, the doors in this case. That will yield the biggest results.
Rear quarter panels and the rear deck are common areas for rattles. And of course, the trunk lid. The floor & roof would be a waste since the floor in a BMW is very well damped abd the CF roof should be VERY stiff. You'll probably have a much larger issue of too much damping, especially in the trunk.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-06-2009, 10:54 AM | #8 |
33
Rep 235
What about the wheel wells, there has to be some way to reduct tire/road noise aside from purchasing higher profile tires. Albeit much quitter than my previous car, there is still room for improvement. It's no 7-series but I shouldn't have to keep the windows down and blast the music just to avoid hearing the road.
2018 F15 X5 - Alpine
2015 F82 M4 - Yas Marina 2010 E92 M3 - Alpine White - Sold |
12-06-2009, 12:46 PM | #9 |
33
Rep 311
I work in the business so I may be able to help. The weight, depending on thickness, is about 1.5lbs./sq ft. We also have light weight dampers, which are effective and less dense... using glass beeds. We manufacture and sell to the distributors private label. It is a butyl compound with aluminum foil. Excellent vibration damper. Keeps panels from vibrating like speakers. These are not insulators. Insulators are like pillows, padding and have to be thick and fluffy. They absorb air borne noise from inside the cabin. Like people talking... so better articulating index is the result. Back to damping. Dampers stop vibrations. So sounds that light up - vibrate - the panels will lose their energy quickly. ie. engine noise - 4 cylinders are notorious at 250 Hz - don't know V8's, road bumps and roads noise will not resonate the panel. Dampers are very effective - most common applications - on Doors, Wheel house, Front of Dash, Floors, Roof - great for rain - and last, rear quarters. Hot Rodders also use them for heat insulation. Ok, it works. Always on the inside of the car though. Can sustain only 250F continous. Aftermarket folks never place properly, so what they do is called wallpapering. Just cover everything. We use laser vibrometer and Head Acoustic recording devices to determine the natural resonant frequency of the panel in question and which area "lights up" the most. These pads are very effective with only 1/2 square foot per door. Ok, here, take a symbol hit it, then put a 1" square of butyl damper on the symbol anywhere, hit it again. Huge difference. Don't do the floor at all. They have asphaltic dampers already there. Actually, if you want to do wonders, take out the less effective asphalt by scraping it off, and put butyl dampers 3/4 the size of the asphalt. Then you'll lose weight and gain acoustic performance on the floor. Assuming the M3 has asphalt like the reg 3.
I wouldn't dampen the Front of dash. I like the engine noise. Actually i'd remove it all. Save it for the Lincolns!
SIGPIC][/SIGPIC] 2008 M3 SSII 6MT, EU Bumper, Matte Black Kidneys, AA Pulley, 12/10 RE Spacers, MS Filter
12-07-2009, 12:43 AM | #10 | |
8 tracks of madness
62
Rep 2,735
12-07-2009, 10:31 AM | #12 |
8 tracks of madness
62
Rep 2,735
They're all pretty much the same. I HIGHLY doubt you'll hear a difference from one to another. I will say this though, they work MUCH better than I thought they would and eliminate a ton of road noise.
12-07-2009, 11:08 AM | #13 |
33
Rep 235
Something like this:
http://www.dkhardware.com/product.aspx?product_ID=26559 I just want quality in a sense it lasts. Something is better than nothing and I just got the car so don't want to buy higher-profile tires now. Also, does smoething like this require an adhesive spray before use?
2015 F82 M4 - Yas Marina 2010 E92 M3 - Alpine White - Sold Last edited by DiamondGCoupe; 12-07-2009 at 11:29 AM.. |
12-07-2009, 12:47 PM | #14 |
8 tracks of madness
62
Rep 2,735
Just hit up a local auto parts store and they'll have something. But they're all formulated with the adhesive so you simply clean the area, mask it off, spray it and let it dry.
12-07-2009, 02:10 PM | #15 |
Rep 164
If you want a superior quality and look's go with Line-X. Its a truck bed liner, it has numerous applications and it works fabulous. I had it sprayed in my trunk of my Evolution MR to reduce exterior noise and rattle from four twelve inch subwoofers. I've read numerous articles on this product, one was the pentagon uses it to line their walls due to it's sound deading properties. I was going to use dynamat but after reccomendations from other people that have used it I was sold.
Heres a good link to get you reading. http://www2.line-x.com/ns/news.html?NewsID=191
2008 E92 M3 Melbourne Red, 20" Iconz 880Z, Gintani race exhaust, HID angel eyes, 6k Interior light kit, Vorsteiner VRS lip
Car for sale thread http://www.m3post.com/forums/showthread.php?t=577829 |
12-08-2009, 10:41 AM | #16 |
33
Rep 235
I called a local dealer, they said they would have to take a look at the wheel wells but gave me an estimate of about $200. I can do it myself for much cheaper but this will probably last longer. Wonder if it dampens the sound the same a foam would? I think for $200 I'd give it a shot can't make it worse.
