ZPOST
  TireRack
      07-12-2009, 02:48 PM   #1
adz648
Drives: Z4 3.0 softy
Carsoft 6.5 problems
Hi to all
i have just installed carsoft 6.5, i have a bought a replica module off ebay.
I have then carried out a full diagnostics scan and it is telling me that all the modules are not responding
any suggestions??
Thanks Adam
      07-13-2009, 09:07 AM   #2
Chuck I
Chuck I's Avatar
20
Drives: '03 Z4 + '07 ///M Roadster
Originally Posted by adz648 View Post
Hi to all
any suggestions??
Thanks Adam
The first question would be, do you have an original copy of CarSoft or a "cracked' copy? CarSoft 6.5 doesn't have all the modules in it. A friend of mine has it and when I run it on my 2003 Z4, it doesn't see some of the modules like the DME. I ran it last night and I see 9 of the modules... but I know a lot of the others I don't have... I'll run it tonight and let you know which ones I do see.. Chuck I
      07-13-2009, 09:40 PM   #3
Chuck I
Chuck I's Avatar
20
CarSoft 6.5 information
This is what I get when they run 6.5 on my 2003 Z4. Chuck I
DME / DDE diagnosis - Status: Module does not respond
Inst. Cluster dia. - Status: OK
SIM - Status - Module does not respond
AIRBAG - Status: OK
ABS/ASC - Status: OK
BC/MID - Status: Module does not respond
DWA - Status: Module does not respond
ZKE / ZVM - Status: OK
HKL - Status: OK
EGS - Status: OK
EWS - Status: OK
LCM / CCM - Status: OK
PDC - Status: Module does not respond
CVM - Status: OK
CAS - Status: Module does not respond
ZGM - Status: Module does not respond
RLS - Status: Module does not respond
      07-18-2009, 01:00 PM   #4
adz648
sorry for the late reply
this is a cracked version that came with the module under the heading of test software
Unfortunately my module can not see any of the modules in the car it says every one in 'not responding'
Any ideas.
i have found some info on another website but it just seems that they have the same problems with no obvious solution
      07-18-2009, 08:50 PM   #5
Chuck I
Chuck I's Avatar
20
Any ideas.
When you plug the cable into your car, do the LEDs light up? You should see the LEDs change color when it's communication with each module. Do you know anyone else with a BMW? If so, maybe you could try it. I know I see a lot more modules on an E46. One thing you might try is opening the folder with CarSoft in it using Explore. Since you have the cracked version, there should be two Icons in that folder. One is the original and the other is the cracked Icon. Try double clicking each. One should work and the other will not... It's worth a try. Chuck
      07-19-2009, 01:57 PM   #6
adz648
With regards to the lights
the module has 5 lights
Power
Service Interval
k-line pin20
k-line pin17
l-line pin15
the only light which isn't on is the 'Service Interval'
I have't looked if they flash whilst i am trying to talk to the Z4 but i will try again in a min
My mate has a 2000 320 coupe so i will try it on his car
Also with regards to the cracked version of the software, i have found the 2 exe files one wont even talk to the car (software crashes) the other gives me the fault of not being able to see any modules.
Thanks for your help by the way
      07-19-2009, 01:58 PM   #7
adz648
also the only 2 modules i need to speak to are the airbag and the cvm
cheers
      07-19-2009, 03:14 PM   #8
Chuck I
Chuck I's Avatar
20
Power
Service Interval
k-line pin20
k-line pin17
l-line pin15
That's correct... the Power should be green and K-Line pin 20, K-Line pin 17 and L-Line pin 15 should be all red... When you run the program you should see K-line pin 20 and pin 17 flashing (you have to look real close to see it... If you see them flashing green and it stays green for about 1/2 second, it means it's not finding the module... when it works correctly Pin 10 and 17 will flash very quickly and each test takes about 10 seconds... Chuck I
zpost
