BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      07-10-2009, 04:43 PM   #1
SWOLE
12
Drives: This week?
Swapping just subs out...
I know there are plenty of people that are experienced with this type of stuff on this board. My question is would I experience any increase in performance if I were to swap the stock subs for SWS-8s and change nothing else? If so, which resistance should I get?
I am not too clever when it comes to wiring whole audio systems but I would like to increase the performance in the lower frequency tones.
Your thought are appreciated. Thanks!
Cheers,
Tom
      07-10-2009, 05:25 PM   #2
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
Cheers,
Tom
I don't think that you will notice the improvement in the standard system. You will definitely notice the improvement if the system is the Premium Audio, however the OEM amp will overheat and shut down due to the change of impedance (from 7 ohms OEM to 4 ohms SWS-8).
      07-10-2009, 05:30 PM   #3
SWOLE
12
Drives: This week?
Thanks for your input, Technic. I do have premium audio, which I should have mentioned. But my understanding is that you could purchase SWS-8s in 8 ohms as well. Is this not true? If it is correct, would the swap be worth it if I were to change nothing else?
Thanks again.
      07-10-2009, 05:38 PM   #4
Technic
Technic's Avatar
2288
Thanks again.
I have not seen an 8 ohms SWS-8... where did you see them?
      07-10-2009, 05:51 PM   #5
SWOLE
12
Drives: This week?
i thought I saw both 4 and 8 ohm speakers on the internet. It was an online stereo/speaker warehouse. I can't find it now, however, so I am probably wrong in that statement. I can only find 2 and 4 ohm variants.
Let me ask this: Couldn't I just add a 4 ohm resistor before the sub to simulate a total resistance of 8 ohms?
If I could find a direct replacement 8 ohm sub would I even notice a difference in the sound?
Thanks again for your help!
      07-10-2009, 06:39 PM   #6
dvn
dvn's Avatar
32
Drives: 2012 C63 Coupe
Are the sub enclosures under the seat both 8" for the standard and premium audio?
      07-10-2009, 07:34 PM   #7
Technic
Technic's Avatar
2288
Definitely adding a 4 ohms resistor should keep the OEM from overheating. However, you will be reducing the power to the SWS-8 in half -slightly less than OEM levels- by doubling its impedance which defeats the purpose of increasing the performance of the OEM subs.
The SWS-8 requires plenty of power to really hit hard, and after my experiment of swapping the OEM woofers with SWS-8, I basically concluded that the improvement was mostly due to the OEM amp putting out almost double its OEM power, from around 150W peak at 7 ohms to 250W-260W peak at 4 ohms than due to anything else. The OEM woofer can hit pretty decent bass if you tweak the EQ bass bands, but the advantage of the SWS-8 is that they hit deeper and cleaner, with this "thuuuump" instead of "thuump" if you know what I mean.
That requires much more power than what the OEM amp can safely produce...
      07-10-2009, 07:35 PM   #8
Technic
Technic's Avatar
2288
Yes, but different woofers.
      07-10-2009, 09:30 PM   #9
Adonislike
26
Drives: Toyota Insight/Honda Prius
Tech, have you changed your system at all since we last spoke??
      07-11-2009, 08:01 AM   #10
Technic
Technic's Avatar
2288
No, I only added a LC6i to better manage the high output levels of the OEM amp into the bit one.1.
      07-11-2009, 04:31 PM   #11
Adonislike
26
Im aggravated the mObridge isnt avail yet
      07-15-2009, 10:42 PM   #12
SCtud
20
Drives: 2008 E93 M3
has anyone tried using the skipass to put in an infinite baffle subwoofer? seems that that would be the best way to add real bass to the car without losing trunk space (which is at a premium for me since i have the convertible).
http://m.mfestforum.com/showthread.php?t=879
This looks like a pretty sweet setup. I am just having a really hard time finding other similar installs and there seems to be a lack of good infinite baffle subs out there.
m3post
