07-08-2009, 03:18 AM | #1 |
86
Rep 303
European front plate adapter
It took several tries, but I was finally able to get from the Paris BMW dealer the correct mounting adapter for a European front plate that my car should have come with (instead of the US mounting plate). For whatever reason, the mounting adapter is listed as available only on the European-spec E92...the first version the dealer ordered was for the M-Technic front bumper for a 335i, and that did not fit at all.
The piece is not too expensive, about 24 euros, and another 15 or so for the BMW dealer to paint it in the factory color (the color matches, except in the photos attached bec of the light reflection). The advantage for me of this over just putting the plate on the front bumper is 1) I can use the same holes to mount the Europ plates as I would use to mount the US plate when I return the car to the US, and 2) it provides a little more cushion in the front in case someone backs into it when parking (not that would ever happen in Paris...). Here are a couple of shots showing the two pieces side by side. The part number for the euro style mounting adapter is 51.11.8.041.166. |
11-25-2009, 01:26 PM | #2 |
8 tracks of madness
62
Rep 2,735
So did the mounting holes line up? I have a different route I want to go for my front plate that won't require drilling (I have an issue with that) but this is a great option as well.
11-25-2009, 02:28 PM | #3 | |
86
Rep 303
I wasn't too keen on drilling holes but high incidence of plate theft and traffic laws here require plates to be permanently attached to the car. FYI: Check out the US-Expat sub-forum for US cars in Europe...and if you haven't already, consider joining M-Flight. |
11-30-2009, 04:27 PM | #4 |
8 tracks of madness
62
Rep 2,735
Yep, been in there but there's not much traffic. I'm considering M-Flight. I've been in a car club (normally VWs though) for a long time but not since I got here in May and I miss it.
On the plate holder you got, how does the plate attach to the holder? I'm guessing it's screwed on? That's how I had to do my GTI's from plate and I didn't like it. I think I'm going to run Skene's front plate mount. |
12-04-2009, 02:25 AM | #5 | |
86
Rep 303
I don't like to use the US plate adapter because 1) it doesn't look/fit right with a european plate attached and 2) it does obstruct the air flow to the grill a little. |
12-04-2009, 04:42 AM | #6 |
8 tracks of madness
62
Rep 2,735
Yeah I hear you on that. The euro plate adapter is a lot better looking. I'm going to do the Skene so I can run either plate without drilling any holes. Sure it won't look as good but my OCD will be happy.
02-14-2010, 09:19 AM | #7 |
402
Rep 1,858
Drives: F80 M3 Frozen Black F87 M2 LBB
Can you post a pic with the adapter on the car? Thanks.
2016 F80 M3 Frozen Black
2018 F87 M2 LBB Follow me on Insta: M3Piotr |
02-14-2010, 05:40 PM | #8 |
//M addicted
Rep 128
Here are pictures of the adaptor attached to the car
02-15-2010, 03:36 AM | #10 | |
86
Rep 303
Here are pics of the euro-size plat adapter on someone's car (not mine). It fits very well, and like I say, provides an extra small cushion for parking mishaps. The mounting points you would use for the US adapter have "twins" on the european one, so you just go with one set of holes.
