06-25-2009, 12:49 PM | #1 |
83
Rep 1,108
Wheel Spacers? Cosmetic only?
I see a lot of people use wheel spacers. Is this a cosmetic only mod or does it actually improve the performance in a measurable way? Are their issues that can arise from using spacers?
06-25-2009, 01:04 PM | #3 |
Automotive Industry Insider
462
Rep 1,948
Spacers are a cosmetic mod, and YES there are issues that can arise by using them...
The best is yet to come...
06-25-2009, 01:07 PM | #5 | |
14
Rep 527
Try searching as there are a lot of threads on the pros/cons of spacers.
2009 BMW M3 Sedan 2013 BMW 535i M Sport Sedan 2014 Mazda3 i Touring Sedan |
06-25-2009, 01:16 PM | #6 |
171
Rep 3,160
Wheel spacers are not only for cosmetics.
Pros
06-25-2009, 01:20 PM | #7 |
286
Rep 6,007
cosmetic only, unless you do something extreme
don't fall for the marketing hype saying your wider track will give you any better handling.
06-25-2009, 02:59 PM | #8 |
221
Rep 4,643
Thanks for creating this thread. I've read many threads on spacers.......But I'm still lost. All of a sudden when I had my mind set on using 15mm spacers all around, now I'm debating whether I should use spacers or springs since the stock suspension is brilliant already.....And I'd hate to mess with it.
06-25-2009, 02:59 PM | #9 | |
BimmerPost Supporting Vendor
257
Rep 4,048
Most people will not even feel any difference and on the track, you probably wont even see too much of a difference in times (if anything depending on the track it's going to be around less than a 10th of a second). But it's not purely cosmetic, there are other slight benefits with it. For the most part though, what we market is the fact that it gives you that bulldog stance: |
06-25-2009, 03:05 PM | #10 |
286
Rep 6,007
yea, it definitely looks better with spacers. I went 10mm all around. I didn't want to go too wide cause I think it looks ridiculous when the tires stick out past the fenders. Although I could've gone wider without that problem. Also the more your tires stick out, the more risk you run to throwing rocks and debris up from the tires onto the side of the car.
But it definitely looks better.
06-25-2009, 03:10 PM | #11 |
221
Rep 4,643
^^So do you think I'll degrade my M3's stock handling by going with H&R 15mm spacers all around combined with RD springs? (sorry, I'm very nervous on this decision since I would love to have the improved look, but I don't want to degrade the stock handling).
06-25-2009, 03:11 PM | #12 |
286
Rep 6,007
the spacers won't degrade it. The Springs probably will, but not to a point where it's going to make a difference unless you're on the track. In fact I wouldn't worry about it at all. Just get an alignment after everything is done and I'm sure you'll be happy with the handling.
The look will be great though
06-25-2009, 03:33 PM | #13 | |
221
Rep 4,643
06-25-2009, 04:16 PM | #14 |
32
Rep 116
Do you track your car or is it mostly city driven?
06-25-2009, 04:17 PM | #15 |
375
Rep 17,017
Most use them on factory wheels or wheels that are not the correct offset to make them flush with the fender. They are for the most part cosmetic although some race applications use it to widen the track. For street use, they are entirely cosmetic.
I recommend going with a solid set like H&R which are forged alloy and will be resistant to cracking under stress. |
06-25-2009, 04:45 PM | #16 |
221
Rep 4,643
06-25-2009, 06:44 PM | #17 |
49
Rep 409
Another question about spacers- will 18 front /15 rear give me a flush appearance with my fenders or will they be sticking out past the fenders.
I'm trying to get the flush look but don't know what size to order |
06-25-2009, 06:54 PM | #18 | |
257
Rep 4,048
▀▄ eas - Macht Schnell wheel spacer reference thread http://www.m3post.com/forums/showthread.php?t=262054 That should really help out! |
06-25-2009, 07:23 PM | #19 |
375
Rep 17,017
That's fairly aggressive for the factory wheels. I typically recommend a 10mm front and 12mm rear but many do 15mm front and 12mm rear.
06-25-2009, 07:35 PM | #20 | |
8255
Rep 18,844
Drives: BMW
The link in Jurrian's post has plenty more pictures.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-25-2009, 08:00 PM | #21 |
49
Rep 409
06-25-2009, 08:19 PM | #22 |
Rep 243
18/15 looks great with 19"OEM wheels. I was concerned that the look would be too aggressive, but I went for it anyway. I couldn't be happier. The wheels look flush and do not stick out beyond the fenders. I haven't seen any damage from rocks hitting the rear fender, but that is somewhat of a concern. IMO, OEM wheels look alot better with spacers.
