ZPOST
  TireRack
      06-18-2009, 11:27 AM   #1
prophetx2
Drives: 2006 M Roadster
E85 V1 Install Video
Figured it was easy enough to film..here's the initial instructions! Enjoy!
[u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/HmVfD55dvLU&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HmVfD55dvLU&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b]
[u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/qofxpoKNpY0&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/qofxpoKNpY0&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b]
      06-19-2009, 05:11 PM   #2
smidley
smidley's Avatar
24
Drives: BMW E60 M5
Great job. I hope we get more people doing video tutorials in the future.
      06-19-2009, 05:34 PM   #3
prophetx2
thanks! i'll be doing one for replacing the stereo too. It took a while for me to wrap everything around my head to understand how it would work but it all makes sense now. I may start next week!
      06-20-2009, 10:04 AM   #4
Matty C
Matty C's Avatar
Germany
20
Drives: 2007 Z4 M Roadster, 2006 M3
Great DIY thread. I will be using this in the future. Thanks
      06-20-2009, 10:43 AM   #5
wyu177
Drives: 2019 m240i
Great job, thanks for taking the time to put together the video!
      08-08-2009, 03:59 AM   #6
mimsterzx7r
mimsterzx7r's Avatar
Drives: 07 M Roadster, 03 Pathfinder
Thanks prophetx for the great video. I just installed my V1 after work and it took me all of 45 minutes. The hardest part was getting through that sticky tape and finding the purple/white wire.
Valentine 1 FTW!
ZHP knob/Zeckhausen CDV/ESS Tune/More to come
      08-10-2009, 08:04 AM   #7
prophetx2
np, glad it helped. It's a really easy install and when I heard some people take this to the "professionals" to do the installl...it's heart wrenching
      08-11-2009, 02:05 PM   #8
apexstrafer
14
Drives: Z4 M Coupe
Did you ever figure out how to get behind the a-pillar to run the remote display wire? Does it just pull off?
      08-11-2009, 02:37 PM   #9
jragan
Imola Lover
jragan's Avatar
26
Drives: 2007 Imola Red M Coupe
How did you decide on using the purple/white wire? I've never head of anyone using that wire...The normal wire to pull from that bundle is the green/white for power only when the key is in the "ON" position (past accessory).
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      08-11-2009, 05:26 PM   #10
prophetx2
I have not had to take off the A Pillar yet, but will be doing a video on that as soon as I get back to Cali for some other things I think. The wire slips between the crevice quiet well.
The purple/white wire was gotten from tons of reading on other posts. It is an accessory power and works just fine as well. I think initially I was looking for the green/white but some of the colors were harder to distinguish..the purple/white just stood out to me.
      08-11-2009, 09:55 PM   #11
jragan
Imola Lover
jragan's Avatar
26
The best tool I've found for pulling wires out of the bundle is a 25-cent paint can opener. Essentially a flat head screw driver with a curved tip. It's great for slipping in and pulling fishing wires out
      07-02-2010, 06:51 PM   #12
phylo
Drives: 2003 Z4
The Video made the install super easy... It took me about 20 minutes to get it installed, the hardest part was getting all the damn wiring tucked away...
Phil
      10-17-2010, 04:06 PM   #13
Car_Girl
Car_Girl's Avatar
Drives: 2013 BMW X5 xDrive 5.0i
Great post! Is the purple / white wire 'switched' power? I was thinking of lower windshield mount and hard wiring into the cigarette lighter but the install you shared through your video looks very simple. I have a 'silence' button on my Bel Pro RX65 and I was going to replace the aux plug under the head unit with the switch. It'll require a dremmel tool to carve out the rectangular opening so I can fit the switch into the rectangular hole and it's in an inconspicuous location with plenty of room behind the panel which I popped off earlier today. I'm debating now, which way I want to mount the detector.
Thanks for sharing - this forum is awesome!
      10-21-2010, 09:10 AM   #14
PatJags156
PatJags156's Avatar
28
Drives: 335i Convertible
So the purple/white wire will only get power when the key is switched to ON? I want the radar detector to turn off automaticlly whenever I turn the car off.
      10-21-2010, 10:00 AM   #15
jragan
Imola Lover
jragan's Avatar
26
You have three types of power:
On All the Time
On at Run/On - Only powered when the car is running
On at Acc - Only powered when the key is at the accessory position
I don't know what purple/white-stripe does but I do know that green/white-stripe is On at Run/On.
      10-24-2010, 03:43 PM   #16
r4gs
Viper Driver
Singapore
36
Drives: F-16
i can verify that the purple+white wire will switch on and off with the car. it is powered with key in position 2.
as an additional comment to the superb diy here, the removal of the reading lights assembly unit and the rear view mirror housing are both not required. i simply spiced into the purple+white, connected the provided main connector, grounded the black wire to one of the two screws inside the housing and used the straight phone line connector and pushed one end through the top of the headliner to pop out on the left side of my rear view mirror. super clean and easy installation, took less than 10 minutes!
zpost
