05-23-2009, 04:54 PM | #1 |
116
Rep 212
This place gave me 30 minutes of my life back... per week!
Maybe I'm the last guy in the whole world that has known this, so if it's an absolute common knowledge, I apologize....
Who said the intarweb is the new idiot box? I've been washing my car almost weekly for near 7 years now, and only now I learn about how you can use running water to dry your car, and I learned it right here. "Using water to dry your car? Wha? I gotta try that!" So, today, I did. After spraying the car, there are millions of water droplets, which stays on the car until you wipe them down. It's a lot of water, so for just the hood I probably had to wring the towel out 3 times.... Then, I removed the nozzle, letting water just flow out of the hose, put the water flow on top of the various flat surfaces, and just let the water run down. The results.... Now just one towel is good enough for the whole car, no wringing necessary. Once again, I apologize if everybody else has known this ever since they started washing cars. It's a bit of a revelation to me, and cut my car washing time by at least 30 minutes. Ahh, the power of internet! |
05-23-2009, 09:15 PM | #3 |
Rep 165
Not only does it save time it cuts the amount of drying towel contact – which can only help with swirls and marring – try the pat dry method to further reduce swirls.
05-23-2009, 09:38 PM | #4 |
612
Rep 10,407
Great tip. I use one of these. Might be even better in combination with your tip. By the way the soft silicone blades are perfectly paint/clear coat safe, provided the car is clean.
05-23-2009, 09:39 PM | #5 |
Track Head
24
Rep 503
Get a water de-ionizer like the ones offered from CR Spotless and you'll be even more impressed! I often follow up by using an electric leaf blower to dry it further and get all the water from the cracks and crevices.
05-24-2009, 10:58 AM | #6 |
Bates '08 Interlagos Launch
126
Rep 1,230
Snother possibly unknown tip that saves time/effort. When drying with a towel, dont fold it up and wipe normally. Let it go out flat across the bonnet or roof, like you were laying down a bed sheet. Then drag from two corners keeping as much surface area intact as possible, drag slowly. I can generally make it work on the side panels too because the water makes it "stick/" Works awesome!
Also, make sure its a old big towel with no fabric softner applied. |
06-03-2009, 09:29 PM | #7 |
162
Rep 621
Drives: 18’c63s,15’macanturbo,14’ 991s
I tried this today and it worked great. I couldn't believe how well it worked. I only used one microfiber and it was barely even wet after. Thanks for the tip
06-04-2009, 12:35 AM | #8 |
221
Rep 2,339
I wouldn't use one of those if somebody paid me to. So many things can go wrong with something like that. I've been doing the water sheeting technique for about 5 years now and it really does cut down on the amount of water remaining on the car. It also gives you a good idea of the condition of your current coat of wax. If the water doesn't sheet well, it's time for another coat.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
06-04-2009, 09:04 AM | #10 |
59
Rep 553
. The investment in the CR spotless system is much more upfront, but in combination with a Ryobi lithium ion battery blower system, this setup is mint.
06-13-2009, 08:56 PM | #11 | |
56
Rep 1,804
I am never using that ever again! |
