04-27-2009, 03:15 PM | #1 |
31
Rep 208
Dinan Springs Installed
I just installed the dinan springs on my 07 m coupe. It was a pretty straight foward procedure thanks to Chuck who was able to send over some pointers before getting started. As far as a review, compared to stock I would say the ride is slightly stiffer but not uncomfortable. The car does stay flatter in hard turns and the drop is about a half inch or so (Will still settle a bit). I did have the H&R springs installed as well and they are definatley a harsher ride. I would say the dinan set-up is ideal if you are looking for a slight drop with some handle enhancement without sacrificing much ride comfort. The H&R's give you more stiffness and less squat but you do sacrifice ride qualitly. For $286 along with 15% rebate and an easy install I am very happy with the springs. I will be getting coilovers eventually but this should hold me over until then. I will post pictures shortly.
BONE STOCK
05-06-2009, 12:10 PM | #2 |
2282
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
can the dinan springs be used in conjunction with stock shocks? b/c i know typically when you run "aftermarket" springs w/o replacing shocks, it'll shorten the lives of the shocks...
05-06-2009, 05:54 PM | #3 |
31
Rep 208
That is typically the case, dinan claims on the websoite that these do work in conjunction with the factory shock but I dont know how much truth is behind that statement. They are not much stiffer than stock, but i am looking to install tck coil-overs in the near future, so i am using these to hold me over. I also like that they are more aggresive than stock but not harsh like the H&R I had on previously.
BONE STOCK
