04-05-2009, 02:12 PM | #1 |
24
Rep 87
Trying to add an AMP and two Subs
I have the standard audio in my coupe. can someone tell me where the factory amp is located for me to tap into to use high level inputs on my amp?
and where the battery is located....I'm so lost with this car. my first german car. always had japanese cars before. and i'll try searching, but can someone send me a link to the wiring diagram for the amp and show me which wire can be tapped for remote turn on. Thanks so much |
04-05-2009, 02:25 PM | #2 | |
2288
Rep 13,001
http://www.e90post.com/forums/showthread.php?t=138949 http://www.fdebrus.be/car/hifi.jpg Amp is on the left side of the trunk under the plastic lid, the battery is on the right side under the tool kit. |
04-05-2009, 03:24 PM | #3 |
24
Rep 87
wow thank you!! that's so clear. I guess the good thing about battery in rear is that I dont have to run 15ft of power cable and drill through the firewall. sweet.
um, I didnt see a remote wire in that post. any ideas for that? |
04-05-2009, 05:03 PM | #4 |
2288
Rep 13,001
... it is the thin black wire in the OEM amp connector...
04-05-2009, 06:46 PM | #5 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
so its as easy as tapping into the remote wire, speaker wires and power from the battery and ground?
no having to deal with error messages etc? |
04-05-2009, 07:32 PM | #6 |
221
Rep 2,339
Since we're talking about the hi-fi system and not the premium system, I would lean towards tapping the line level signal before the amp instead of the speaker level signal after the amp.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
04-05-2009, 07:47 PM | #7 |
2288
Rep 13,001
The problem with that is that a specific differential input amp/line output converter will be required, something that drastically reduces the variety of possible aftermarket components to achieve this simple sub add-on.
04-05-2009, 10:01 PM | #8 |
687
Rep 6,845
that's what i meant
to unplug the connector going to the amp and tapping into that thereby bypassing the amp alltogether not just for the subs but for front and rear speakers can't i take the input wires going to the amp into RCAs? |
04-05-2009, 10:31 PM | #9 |
2288
Rep 13,001
You might want to start your own thread, as the OP only wants to add a sub to his system. What you want is to replace the OEM amp...
04-05-2009, 11:08 PM | #10 |
687
Rep 6,845
oh
i only the read the part about adding an amp and i clicked the thread sorry OP didn't mean to side track your thread |
04-06-2009, 06:48 AM | #11 |
50
Rep 470
04-06-2009, 06:39 PM | #12 |
24
Rep 87
If I just tap the thin black wire for remote turn on, those color coded speaker wires for my high level input to my amp, ground to the body of the car and power cables to the battery, will I set off any error msgs or mess with the electronics of this car?
anyone with the above set up had any problems with electronics malfunctioning and maybe bad bass quality with this set up? |
04-06-2009, 06:42 PM | #13 | |
2288
Rep 13,001
You might use a fuse/relay with the remote turn on wire for protection, though. |
04-06-2009, 08:39 PM | #14 |
24
Rep 87
