04-11-2009, 04:57 PM | #2 |
60
Rep 377
Drives: 08 E92 AW M3
i would like to know as well.
04-11-2009, 05:03 PM | #3 |
351
Rep 2,937
Drives: 2013 Estoril 328i M Sport
I would use a pressure washer, as it's the one solution that doesn't touch the car. A GOOD clear bra install won't peel if hit with high pressure water. I live by the idea that the less you rub the car with a microfiber or anything else, the better, and pressure washers accomplish this.
04-11-2009, 05:16 PM | #4 | |
36
Rep 1,043
how thoroughly are you able to wash with a pressure washer? ive always wondered if with a good pressure washer, foam lance and leaf blower you could completely wash/dry a "lightly soiled" car without ever touching it.... almost like a touchless car wash, although they use powerful detergents... |
04-11-2009, 05:52 PM | #5 |
351
Rep 2,937
Pressure washing can't replace a good wash mitt/two bucket method. Pressure washers are used to blast off the majority of dirt on a car, not clean off the dirt that is firmly attached to the car. I said use the pressure washer for the edges of the clear bra because it's hard to get buildup out of those edges with a towel without slightly scratching the bra.
04-11-2009, 06:14 PM | #6 |
The Jesal
391
Rep 5,859
Corners? AS in the line that shows from the clear bra?
Normally i take a microfiber towel, mist it with quick detailer then take my finger nail behind the microfiber and gently go along on the line.
2009 E90 M3 - SOLD
04-11-2009, 10:43 PM | #7 | |
Rep 58
Now if the film has already lifted and it has dirt under the film, there is nothing you can do about that. A pressure washer will only make that situation worse... causing the film to lift even more and open it up for more dirt to get under it. If it has lifted then you should take it back to your installer and have it replaced. |
scrammer422.50 |
04-11-2009, 11:14 PM | #8 | |
351
Rep 2,937
1. Spray along the clear bra's edges with a pressure washer from several feet away. 2. Spray QD along the edges then wipe down with a microfiber. After you use the pressure washer, you'll have minimal dirt that will get trapped in the microfiber. I have a VentureShield bra on the entire front end of both my M5 and M3, and dirt builds up quite heavily along the seams. The last thing I'd ever do is drag dirt up into the microfiber. While my solution is fairly excessive, I'd wait to wash the car with a PW rather than use a QD + microfiber on a dirty surface. While many "professionals" say it's OK to clean parts of a dirty car with a quick detailer and microfiber, I WOULD NEVER RECOMMEND IT. |
04-11-2009, 11:22 PM | #9 |
The Jesal
391
Rep 5,859
I made the assumption that the car was already washed and he was just trying to get the light dirt/wax build up out of the lines.
2009 E90 M3 - SOLD
04-12-2009, 02:47 AM | #10 | |
Rep 426
Drives: '09 E90 M-DCT M3
What PSI would you recommend. I always assumed a pressure washer would strip off any wax, leaving the non-bra'd portions of the car pretty much unprotected. This would be great for me though, since the pollen around here is driving me nuts on the interlagos!
AiB LEDs///MS Filter///Hardwired V1///VentureShield///F1 Pinnacle 35%///IND Reflectors///BMW Performance Grills
