03-02-2009, 07:52 PM | #1 |
48
Rep 636
Smartphone Revisited.........
I finally received my iPhone cradle and snapped it into the smartphone set-up under the center armrest. It does everything it's supposed to do...play music, receive calls, place calls, charge the phone, and get better reception. The last feature, better reception, I decided to test. I have a friend who lives out in the country and my iPhone is dead out there. So as I drove out , I marked the spots by writing a little note as to where the I began losing bars on the iPhone, not plugged into the cradle. As I got within 1 mile of my friend, the iPhone said "No Service". So I stopped and turned around and stuck the iPhone into the cradle....amazing...."No Service". As I retraced my steps, the bars increased at almost the exact same spots as before. There was no better reception using the car's antennas, at least none that I could find. I could have saved the $150 for the Smartphone Integration and the $175 for the cradle and just used the iPod cables and chad the same results....not as nice looking of course. So the only test left for me is whether I sound better over the iPhone while it's plugged into the cradle. My voice was somewhat distorted, at least when I called my wife, with the iPhone hooked into the iPod connector. Hopefully the cradle will prove to be worth it...so far, no good.
03-02-2009, 11:11 PM | #2 |
Lurker
Rep 58
Drives: 09 AW E92 M3
Interesting. Thanks for posting your findings. I got the cradle but my main concern was locking the iPhone in place, and freeing up the Y-connector for my iPod. That said, I am disappointed if there is in fact no gain in signal strength.
03-03-2009, 09:58 AM | #4 |
10
Rep 125
ok, can someone please help me. I have an iphone 3g and I have m drive. I don't have the ipod option though. What would I need to do so I can get the iphone cradle and ipod integration? I have no idea what these 6fl and the like acronyms stand for. Any help would be appreciated
03-03-2009, 10:09 AM | #6 | |
Lurker
Rep 58
The quick answer is: 6NF - Smartphone Integration - Provides the platform to allow bluetooth connectivity with your iPhone (or other smartphone). Also is the starting point for playing music from your iPhone. To actually play music, however, you will need either 6FL (Y-Cable), or the iPhone 3G cradle. 6FL - Y-Cable - Hooks up in your armrest. Provides music playback from your iPhone and searchable access from iDrive. 84 21 2 151 038 - Cradle - for the iPhone 3G adapter in cars without 6NF option. 84 21 2 151 043 - Cradle - for the iPhone 3G adapter in cars with 6NF option. I sure hope I explained that right. If anyone knows different, please clear it up right away. I don't want to lead anyone astray.
03-03-2009, 11:53 AM | #8 | |
2288
Rep 13,001
None of the two adapters can be retrofitted to your car as of today, so forget about 6NF or 6FL. The only OEM adapter that can play music off your iPhone is the dealer-installed MOST iPod adapter: http://accessories.bmwusa.com/ItemVi...&productId=748 For the iPhone to be connected to the external OEM celular antenna in the sharkfin in the rear of the roof you will need a specific iPhone cradle and an eject box. This will not allow you to play any music once the iPhone is snapped into the cradle. To play music you will need to remove the iPhone from that cradle and plug the MOST iPod adapter to the iPhone. The Bluetooth connection will be still active for phone calls... |
03-03-2009, 01:24 PM | #10 | |
Lurker
Rep 58
03-03-2009, 01:38 PM | #11 |
32
Rep 412
So if you are ordering a 2009 with the technology package, would there be any reason to get the smartphone integration? Can you get the cradle instead and be good to go?
03-03-2009, 04:55 PM | #12 |
48
Rep 636
Without the smartphone integration, the cradle is useless. The smartphone integration gives you interface into which to attach the cradle.
03-03-2009, 06:32 PM | #13 | |
2288
Rep 13,001
However, the Smartphone option for MY2009 requires the iPod adapter factory option. Neither option can be retrofitted in the USA in any M3 regardless of model year. The MOST iPod adapter is the dealer-installed accessory, which can be installed in any MY M3 without the factory iPod adapter. |
03-03-2009, 06:38 PM | #14 | |
2288
Rep 13,001
The Tech package is not a requirement for the Smartphone option. Assist/Bluetooth and the iPod adapter (6FL) ptions are required. You still can get the regular, non-6NF, cradle and eject box and use it with the iPhone if the Smartphone option is not selected. But it won't play any music while the iPhone is in the cradle. |
03-03-2009, 07:19 PM | #15 | |
32
Rep 412
03-06-2009, 02:31 PM | #16 |
19
Rep 432
Drives: 2009 Melbourne Red Coupe - DCT
I think the main difference is the streamlined look of the smartphone integration... I haven't noticed a major difference in anything else.
2009 Melbourne Red DCT | Black Interior | Carbon Fiber Trim | Carbon Fiber Roof | Cold Weather | Premium | Technology | 19's | Smartphone Integration | iPod |
03-07-2009, 06:17 PM | #17 |
26
Rep 842
I just got my second cradle after the first one proved to be defective. There is absolutely no difference in cell reception being plugged into the cradle. My phone has full signal, I can hear the person on the phone crystal clearly, but I continue to be choppy when I speak. I firmly believe it is a problem with the iPhone. I have a much less-capable Verizon phone that when synced into the bluetooth, I sound perfect to whomever I am speaking with. Very irritating
03-09-2009, 11:04 AM | #18 |
Rep 280
Thanks, JIO. I've been tracking this since the last thread. I broke down last week and ordered the cradle... presumably for better reception. So much for that. Now, and extra $175 for a clean-looking, plastic phone holder...
Hope someone figures out the real "plus" for ordering the cradle. (When I was at the dealer, testing the 3G, the Y-Cable proved to do just fine for full functionality).
'09 E92 ///M3 | Jerez Black/Black Leather | Sycamore Anthracite | MDCT | Premium/Tech/Cold Weather Packages | 19" | Moonroof | Enhanced Premium Sound |iPod/USB | Smartphone
'97 E36 M3 Sedan Hellrot Red/Black; '03 E46 330Ci Met. Gray/Black; '06 E46 330Ci ZPF Imola Red/Saddle |
03-10-2009, 05:25 PM | #19 |
49
Rep 376
Drives: '15 M4
I don't get the point of the smartphone integration if you have to use it with bluetooth... isn't the whole point to get a clean connection to the car as opposed to using the ineffective wireless bluetooth...? clarify please!
Questions: I have a 2009 model with smartphone integration and the ipod usb integration... 1.) will the iPhone cradle fit fine with iPhones that have a case (incase specifically) around them? 2.) Do you think it's worth getting the iPhone cradle if I already have the Y-cable...?
09' E92 M3 | IB |Black | Carbon Leather | 19" Option Wheels | DCT | Akrapovic Full Exhaust | Arkym Rear Diffuser | Arkym Front Bumper | Macht Schnell Stage 2 Intake | (Delivered 3/7/09)
RIP!!!! Miss you dearly '12 X6 M Carbon Black / Akrapovic Evo / AR Design downpipes / ESS tune |
03-10-2009, 05:30 PM | #20 | |
Lurker
Rep 58
2.) Based on others' reports that reception is not improved with the cradle, I'd say there is little reason to get the cradle if you already have the Y-cable. I have the Y-Cable and the cradle. For me, I like having the cradle hold down my iPhone (no sliding around while driving). I also prefer to use my iPod for music, so I hook it up to the Y-Cable and my iPhone in the cradle. This allows for both devices to be charged at the same time, with music coming from my iPod (Y-Cable) and conversations coming from my iPhone (cradle).
03-10-2009, 05:35 PM | #21 | |
126
Rep 4,144
I'd like BMW to come out with a cradle for Verizon's Samsung Omnia.
2017 F80 YMB.
03-10-2009, 05:48 PM | #22 | |
49
Rep 376
Drives: '15 M4
Anyone know if the cradle will fit an iPhone with a case on it?
