BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      02-25-2009, 03:26 PM   #1
niqui
niqui's Avatar
127
Drives: Jet Black E92 M3
1st service: no transmission fluid change?
hi
i just had the 1st service, and the rep said all fluids were changed and tested, and the m differential and the filters, but he said the transmission fluid was not, it is good for life,,,
is this true, i dont recall whether they are supposed to change it or not?
its a manual e92 m
      02-25-2009, 03:29 PM   #2
JuniorDee
JuniorDee's Avatar
74
Drives: the speed limit
I had mine changed. I believe most people here are having it changed
some may disagree, but i dont think that any fluid used in a car should be lifetime
EDC.....viagra for your car
      02-25-2009, 03:50 PM   #3
niqui
niqui's Avatar
127
so does that mean i should have had it changed?
i assume it cant cause damage to the car or be a big deal, i will check the manual, to see if it says theyre supposed to change that.
      02-25-2009, 04:23 PM   #4
Heat00
Heat00's Avatar
51
Drives: 2008 E90 M3
they did my oil, filter, diff fluid and tranny fluid at 1200.
08 - M3 Sparkling Graphite/blk leather/tech/6 speed
08 - 335i Sport/Prem/Auto White/Terra - AA Exhaust
07 Acura MDX Tech, 07 G35S /Nav
      02-25-2009, 04:32 PM   #5
!Xoible
837
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
yes for manual, no for DCT
      02-25-2009, 04:48 PM   #6
niqui
niqui's Avatar
127
is it a big deal, should i go back?
because, i asked him right when i picked it up, and he said they never change it?
in my manual it doesnt say,
      02-25-2009, 05:16 PM   #7
mkoesel
Moderator
7515
Drives: No BMW for now
Yes it should be changed for your car, since you have a 6MT. The service tech was wrong, so take it back and ask them to change it.
      02-25-2009, 05:19 PM   #8
vm
Drives: 2018 Alfa Romeo Giulia
IMHO yes. This problem arised because when DCT came out there were several instances in which the techs changed the DCT fluid (DCT doesnt need the change) and used the manual transmission fluid, ruining the DCT transmission. The confusion was because the SMG transmissions need the same services as the manual one and use the same fluids. My speculation is that to avoid that problem BMW now recommends no oil change at all but I havent seen anything in writing. Check http://www.bimmerfest.com/forums/sho...d.php?t=341406
      02-25-2009, 06:06 PM   #9
niqui
niqui's Avatar
127
thanks guys, ok will do, i take it its not a big rush.
i will drop the car to them this sunday and tell them to do it.
thanks
anything else i should ask about, filters and oil and differential all done, he said.
thanks again
m3post
