      09-03-2008, 06:15 PM   #1
imported_McLovin
imported_McLovin's Avatar
Drives:
Low oil after only 1800 miles.
On the way home from bringing my boy to football practice the oil light came on. I check the onboard computer in the driveway and it's below the min mark. It says +1 quart. The manual says not to drive the car more than 125 miles or engine damage may occur. Good thing I already made an appointment with the service department for a rattling noise. It goes in on Friday.
My thoughts on this are....
      09-03-2008, 07:52 PM   #2
imported_mega
No_Country
122
Drives: various bmw's
curious, did you do a hard/load break in?
or did you really baby the car?
I'm at 1100 miles and mine still shows full, I did a hard/load break in, but did not ever go over 5500 rpm (still have not)
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      09-03-2008, 08:17 PM   #3
imported_McLovin
Drives:
I went to redline a couple times right after I got the car but I haven't been above 4500 rpm since. Top speed has been no more than 85 mph. :iono:
      09-03-2008, 09:05 PM   #4
imported_mega
No_Country
122
I can say for sure that some engines will not properly seat the rings unless they have a load put on them at break in, with motorcycles you simply go into a high gear and go WOT with it a few times to put high loads on the rings to seat them, or you'll end up with lots of oil burning
not sure if this is the same with cars, I've never gone into a really new engine to see how they were seating, or a turbo that already has much higher cylinder pressures
      09-04-2008, 08:09 AM   #5
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
And sensors can be inaccurate (sure wish this engine had a dipstick). Mine was registering Full with only 6 qts. after I changed the oil at 1500 miles. Added the 7th qt. and still registered Full. :iono:
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      09-04-2008, 02:11 PM   #6
imported_McLovin
Drives:
I'll have them check it out and I'll let y'all know what happens. Hopefully it's just innacurate sensor. The car was parked at an angle on a hill at the field so maybe that had something to do with it. The wife drives the car during the day so I'll see if the light came on again today.
      09-04-2008, 03:06 PM   #7
My135
85
Drives:
Very likely (90%), the oil sensor gone bad. If this is the case, you don't have to worry anything. Just take it back to the dealer for a replacement.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      09-04-2008, 03:19 PM   #8
jbenington86
58
Drives: 2015 M235i, 2017 Tundra
2015 M235i  [0.00]
2008 128i  [0.00]
almost 4k miles no light for me..yeah yeah i dont need an oil change lecture
      09-04-2008, 03:40 PM   #9
imported_McLovin
Drives:
The wife just got home and the car reads fine now, it must have been because it was parked on the hill. Damn that had me freaked out. I feel better now. :biggrin:
      09-04-2008, 09:16 PM   #10
WhiteOne
28
Drives: 2008 AW 135i
I hear 6.9 quarts are needed when doing an oil and filter change.
      09-04-2008, 11:42 PM   #11
Robert
416
Drives: 135i -> is350 -> Tesla M3 perf
I used 7 last time.
- There's nothing in my pocket other than knives and lint
      09-05-2008, 07:23 PM   #12
Mad Dragon
Mad Dragon's Avatar
27
Drives: 2010 GTI
I always use 7. That last 0.1 qt isn't going to make a difference.
      09-05-2008, 11:06 PM   #13
1Ronnie
Ronnie
1Ronnie's Avatar
15
Drives: '08 Sedona 128i
I had the same thing happen in my '06 323i, I thought something was wrong, but the car was pretty insistant that I chuck a litre in NOW. I did so, and never had another issue with it.
"Lucy"
128i / Sedona Red / Coral Red / Premium Package / Premium Sound
1addicts
