06-05-2008, 09:27 AM | #1 |
Rep 75
Sirius signal drop outs?
While driving my car, Sirius drops out periodically - anywhere from a faction of a second to several seconds. I've never had satellite radio before so I'm not sure if the signal loss is normal or if there might be something wrong with my radio. Any thoughts?
06-05-2008, 09:56 AM | #2 |
... and Orca too!
29
Rep 845
It needs line of sight to the satellite, so it will drop out if you go under a bridge or other block (maybe dense trees or close to tall buildings). And after it has the sight again, it takes a few beats to sync up again.
amy! |
06-05-2008, 10:10 AM | #3 |
Rep 36
Had Sirius for a few years on my previous car and had the same issue. Sometimes you'll even struggle to get a constant connection on really cloudy days.
135i Black Sapphire Metallic/Coral/Aluminum/6MT/Sports/Heated Seats/Ipod/Sat
06-05-2008, 10:20 AM | #4 |
20
Rep 841
Sirius appears to have a network of terrestrial repeaters:
http://www.dogstarradio.com/sirius_map.php Are there fewer dropouts in the areas that are covered by these repeaters? |
06-05-2008, 10:21 AM | #5 |
2148
Rep 10,176
Have had Sirius in 4 cars so far, and have never had it cut out due to clouds before. It definitely does cut out in tunnels, underpasses, and heavy tree cover. It actually cuts out less in the winter, when there are less leaves on trees.
Your experiences may vary, because you "look" at the satellites from a different angle based on where you are on the earth. On a side note: When are they going to stick a few MB of memory in those receivers, so that they can cache a few minutes of music, and you do not get any interruption. It seems like it would be basic to be able to accomplish! (yeah, I know that for live broadcasts, you can't do that...) |
06-05-2008, 10:23 AM | #6 |
Upstart
14
Rep 142
Mine drops out often too. We have a lot of trees where I live, but it doesn't always drop out near the densest trees. It's hard to predict. My wife has XM radio in a Honda CRV and hers never drops out, except under overpasses. I'm putting this on my squawk list for the dealer.
06-05-2008, 10:43 AM | #7 |
29
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
Mine drops out within heavy treed areas and inside my garage. I believe this to be perfectly normal.
My Sirius drops out far less than my wifes XM (oh by the way).
2008 135i SGM |
06-05-2008, 11:28 AM | #8 | |
Rep 36
Agree with you on the memory option. My old car had the Sirius Sportster with the cache, which greatly improved the radio experience, just like TiVo dramatically altered my TV viewing habits.
06-05-2008, 01:34 PM | #9 |
Rep 75
Thanks for the information - most likely its normal drop outs due to trees or other obstructions. I might have the dealer check it out anyway.
BTW: I did check the repeater map - there is an "unconfirmed" repeater in my area. |
06-05-2008, 01:36 PM | #10 |
Rep 76
mine has been extremely reliable in the 4 or 5 years I've had it. Very very occasionally it'll skip if it's changing satellites but it's very rare, and of course going slow under bridges or overpasses, it'll skip just for a sec. But over 55 or 60, usually not even then.
06-05-2008, 02:00 PM | #11 |
1er
73
Rep 1,205
Sat radio is S band which is 2.4GHz. Stuff at this frequency is pretty sensitive to any physical blockage like a tunnel or a building, but it is not so sensitive that rain would block a signal. Satellite TV uses over 10GHz and is very sensitive to anything blocking the signal path, even rain or snow, for comparison.
The old 49Mhz cordless phones were more tolerant and could go through even brick walls relatively easily (although not very far). |
06-05-2008, 02:20 PM | #13 |
1er
73
Rep 1,205
I happen to think sat radio sounds like crap, but I like the content, so I record the higher bitrate stream off of their internet feed and put it on my ipod (which also lets me fast forward it and listen to it in tunnels).
My mac mini records a few hours of my favorite channel every day and syncs my ipod automagically overnight. |
06-05-2008, 02:34 PM | #14 |
Rep 75
06-05-2008, 03:06 PM | #15 |
1er
73
Rep 1,205
06-06-2008, 09:53 AM | #17 | |
Ronnie
15
Rep 556
"Lucy" 128i / Sedona Red / Coral Red / Premium Package / Premium Sound |
06-06-2008, 10:49 AM | #18 |
1er
73
Rep 1,205
Yeah, buffering only works if the data stream is variable speed. Plus every time you changed channels it would take forever.
