      04-26-2008, 04:39 AM   #1
imported_dexter
Drives:
Rubbing with 19" rims
i put a set of 19" rims on my convertible 1 series (M pack), its fine with regular driving. but when ever i go over speed humps i have to brake to under 5mph or i get rubbing on the wheel arches when the wheels bang upwards due to the hump. is there any solution to this ?
i could have the arches rolled out although this may ruin the look of the car???
i could have the car raised 1 inch, but will this ruin the M suspension i had to pay extra for or the ride quality drastically???
i could buy a set of tyres with a lower profile than the ones i currently have on, but will that make any difference???
thanks for you feedback
      04-26-2008, 05:52 AM   #2
josh
12
Drives: E36 M3, 135i
Why would you want 19" rims on it?
      04-26-2008, 06:00 AM   #3
Kiwi
New Zealand
145
Drives: 2015 BMW M Sports Convertible
I think you have made mistake fitting 19" wheels.
      04-26-2008, 06:07 AM   #4
fedex
Drives:
A 36HH rack on a chick doesn't work/look right for the same reason a 19" wheel (with probably the wrong offset) doesn't work/look right on a 1 series. I call it 'Proportion'.
With that said, you can try a lower profile tire as well as stretching a less wide tire on the rim. I would try to sell/return those 19"s though, as those sized wheels are actually 'ruining' performance on your car.
...Tommy
      04-26-2008, 07:18 AM   #5
randomquickness
219
Drives: 996tt
keep the 19's...get a lower profile tire set up.
      04-26-2008, 07:24 AM   #6
BMW Dreamer
BMW Dreamer's Avatar
72
Drives: Modded 06 TL Manual
If you really want to keep the 19's, get a lower profile tire.
What size tires are you using on the 19's ?
Rolling the fenders shouldn't change the look of the car.
Do the tires stick out with the offset your using, or are they tucked in more?
Personally I will leave the 264's on my 135i. They look great, and they are designed for the car. Plus they are probably pretty strong even though they aren't forged.
      04-26-2008, 07:53 AM   #7
imported_dexter
Drives:
the tyre size at the moment is
235/35ZR19 91W XL
the do stick of a tiny bit beyond the back arch i think, maybe in line with the arch but definately not behinde the arch
      04-26-2008, 08:13 AM   #8
randomquickness
219
Drives: 996tt
I don't really see that size posing a problem...most likely the offset is just a little too high. got any pics?
      04-26-2008, 08:55 AM   #9
BMW Dreamer
72
235/35ZR19 91W XL
Are you saying the rear hit over RR tracks or do the front hit when cornering? More info please.
I would maybe suggest a 225/35/19 in front and a 255/30/19 in the rear. If you want the same all around maybe 235/30/19, 225/30/19
      04-26-2008, 08:58 AM   #10
natedog_1959
Drives: 2004 SVT Focus
Sounds like you rear offset is too high. How much space do you have between the back of the rear wheels and the shock? Pictures would be worth 1000 words. Nate
      04-26-2008, 09:20 AM   #11
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
Yes, more information is needed. First, what is the offset of the wheels? Where, exactly is it rubbing? The fender liners on the 1-Series seem to intrude into the fenderwell more than on some cars. And as previuosly noted close-up pics where the rubbing is occuring would be very helpful.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      04-26-2008, 02:13 PM   #12
imported_dexter
Drives:
i fixed the problem the edge of the tyres was hitting the inside edge of the wheel arches.
so i change the tyres to ones with a more curve edge, than the square edged ones before.
now it runs fine on 19's and i can even go over speed humps at 35mph with no rubbing or banging
      04-26-2008, 02:31 PM   #13
BMW Dreamer
72
PICTURES PLEASE
Congrats on solving your problem.
      04-26-2008, 02:36 PM   #14
mikeo
Santa Fe Concorso
mikeo's Avatar
103
      04-26-2008, 04:05 PM   #15
ichiban
ichiban's Avatar
94
Drives: 08 135i
Lower the car, put some camber on it. Also get smaller width tires and lower profile would all help.
      04-27-2008, 06:25 AM   #16
imported_dexter
Drives:
pictures with new tyres ----
front
rear
close up
front profile
      04-27-2008, 06:34 AM   #17
Kiety
The ONE
12
Drives: BMW 135i Cabriolet
that looks awefully hard to keep clean, but it goes with your black
135i Cabriolet | Sparkling Graphite Metallic | Coral Red Boston Leather | Moonlight top | Glacier Aluminum trim | Premium package | M Sport package | Sound package | PDC | Power Seats
      04-27-2008, 08:37 AM   #18
groovyjay
Individual1
groovyjay's Avatar
Drives:
front
rear
close up
front profile
How wide are the wheels? What offset? Any more pics showing the whole car? :headbang:
      04-27-2008, 10:23 AM   #19
TunedM2C
TunedM2C's Avatar
No_Country
829
Drives: 2016 LBB M2
Do you have any pictures from afar?
      04-27-2008, 10:45 AM   #20
walsh416
Drives:
+1:headbang:
      04-27-2008, 11:10 AM   #21
imported_dexter
Drives:
Originally Posted by walsh416 View Post
+1:headbang:
btw width on first tyres i tried were 235 these are 225 and are fine
      04-27-2008, 11:25 AM   #22
morscode
Got Boost?
morscode's Avatar
52
Drives: 19 x3 m40i
negative camber ftw
1addicts
