04-13-2008, 12:03 AM | #1 |
44
Rep 657
Tire Dilemma (Spring Related)
So I originally went with 18x8.5 all around with 225x40x18. The wheels fit fine with the stock springs. Then I went and swapped out the springs with H&R sport. Initially it was fine, but now that the springs have settled there is a slight rubbing of the outside sidewall of the tire (turned) with the fender when I'm on an uneven surface at slow speeds, like parking on a sidehill.
What is the best possible solution? A. Move to smaller front tire size with the 18x8.5? B. Move to an 18x8 in combination with a smaller tire (215)? C. Yank out the H&R sport and go back to stock? D. Do Nothing, its not going to hurt anything, its typical. E. Other? Suggestions appreciated. I have a driving school coming up in 2 weeks, so I would appreciate some advice. I would like to get this resolved before then, preferable with the least amount of cost. |
04-13-2008, 07:53 AM | #2 |
Rep 153
Have a professional roll the fenders a 1/4". You will not even notice it in the looks department and it will probably cure all your problems. Should only cost a couple hundred bucks if that. You have put too much money into you wheels and tires to change now. As an aside, I am getting the new Z1 Star Spec tires for my SVTF next weekend at the TireRack. I can't wait. Nate
04-13-2008, 07:57 AM | #3 |
2148
Rep 10,176
Rolling your fender only rolls the inner lip so that it's flat against the fender. I agree with natedog. Sounds like you have a slight rubbing problem.
On the track, you're in deep doo-doo if you have the wheel locked to either side too. Steering input at speed is far less than in a parking lot. |
04-13-2008, 05:18 PM | #6 |
36
Rep 1,329
what is the offset on those wheels
also if it is just rubbing a little you may want to think about removing the alignment pins. that fraction of a degree of negative camber may be enough to solve your problem. |
04-13-2008, 09:34 PM | #7 |
44
Rep 657
18x8.5 et42. Let me know. I really want to avoid rolling the fenders.
04-15-2008, 02:01 AM | #9 |
416
Rep 6,968
- There's nothing in my pocket other than knives and lint
04-15-2008, 05:31 AM | #10 |
72
Rep 2,387
Thats what I would do, get the best adjustable coilovers like Tein. But get the SS with adjustable damping. They adjust height and ride firmness. I learned that lowering has many down sides. Sure it looks cool and may handle better though.
In the long run leaving it stock is MUCH better IMO. But its your car and coin $$$. |
04-15-2008, 07:05 AM | #11 | |
PCA, BMWCCA
102
Rep 2,058
Personnally I'm not satisfied that any aftermarket wheel makes have ideal solutions for the E82. Good coilvers, like KW or Bilstein (wouldn't dare choose anything else), are far better bang for the buck than wheels, and there are already today applications specific to the E82. I care far more about handling/cornering than what my wheels look like, so my money would be on coilovers, stock wheels, and conventional rubber. It's your wheels (and tire combo) that are causing you all the grief. Return them ASAP!
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
04-15-2008, 10:10 PM | #12 |
72
Rep 2,387
YAH I forgot the minimum lowering with Tein SS coilovers. They adjust from 1.25-3". Thats one reason I just put Eibach Pro springs on my TL-S. They lowered the car about 1"
04-16-2008, 05:59 AM | #13 |
16
Rep 355
Do as others have suggested and switch your springs back. Where is your driving school. If your tire rubs while driving at slow speed, even slightly, don't even think about taking it on the track. It it rubs on the leading edge of the lip, like anything between 9 and 12 o'clock position, it is the worst case scenario. After changing tire sizes (on the 911) I had no rub on the left front fender lip through full range of turning. That was the next event at the Glen. The climbing esses - taken in fourth with foot on the floor. Suspension fully loaded, the tire not only rubs, it grabs the lip of the fender and pulls down. Needless to say, I came in and readjusted the fender of my previously pristine 911. Fortunately this occurred on the second warm-up lap and the damage was slight. Others have buckled the fender. Rolling would have been prettier. You will have a hard time simulating the loads your suspension will see on the track.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 -- 13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile |
04-16-2008, 06:39 AM | #14 |
29
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
Thankfully the car was pink.........that made watching the vid much less painful........can you say OUCH !!!
2008 135i SGM |
04-16-2008, 11:15 AM | #15 | |
44
Rep 657
04-16-2008, 12:02 PM | #16 |
16
Rep 355
Watch the deer!! The 911 took out another deer on Friday (of a 3 day). Sunday was 100 days on Summit Point Main and I have two deer hits and no confirmed kills. (rant portion moved to track portion)
Alan
04-16-2008, 12:49 PM | #17 |
2750
Rep 6,759
If you have just a slight rubbing issue when loading the front wheel going over a speed bump (or driveway etc.), then I would suggest keeping your springs, removing the strut alignment pins and rolling your fender.
I think will give you sufficient clearance for this type of situation. You can also test the result perhaps by driving the front wheel over a rhyno ramp, then turning the wheel end to end. Please note that if you remove the pin, you will need a 4 wheel alignment (and specify as much negative front camber as possible). As others have pointed out, any other lowering suspension will give you the same problem - might as well deal with this now.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
