05-07-2024, 10:58 PM | #1 |
1489
Rep 1,917
PCV/Oil Smell after driving the car hard
I am a bit baffled at this.
Whenever I drive the car hard there is always a PCV/Oil smell that sometimes comes into the cabin but almost always stinks up the garage after parking. I have spent over $10,000 overhauling the car over the past year which included the oil separators, PCV valve, valve cover gaskets and OFHG. To the best of my knowlage the car does not leak any oil. There is always a little seepage around the oil filler cap (which was also replaced) leading me to believe there is positive crank case pressure. My mechanic recommended I install an oil catch can. If I am being honest I am ready to move on from this car. I feel like I am finally always at the finish line and can enjoy the car but then something else pops up. Thoughts? |
05-08-2024, 12:23 AM | #2 |
1627
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
Smoke test?
05-21-2024, 08:47 AM | #3 |
BimmerPost Supporting Vendor
3784
Rep 2,918
Drives: 2011 E93 M3
If you only replaced gaskets and not the valve covers, I'll bet dollars to donuts that you have oil leaking onto the exhaust headers. The PCV system is very robust on this engine and rarely fails. A catch can is the last thing I would recommend on this engine.
05-21-2024, 01:08 PM | #4 | |
424
Rep 304
The shop told me they warp over a long period and will never seal properly after that amount of time so valve seals and covers are recommended together. You might need to shop around and find a shop that knows this engine and platform better if they missed this step. Just an FYI, I'm about $19k into mine for maintenance over 4 years. You don't have to go that far yourself, but it's very easy to end up there if you don't pay attention to the car and what jobs you can do yourself. It does even out and they're not making this type of car again, so for me it's worth it. Last edited by Cmassey3; 05-21-2024 at 01:17 PM.. |
smokinjoe64663.00 |
05-21-2024, 04:20 PM | #5 | |
Naval Aviator
663
Rep 694
Now don't feel so bad ...circa 2020 spent >$30K on replacements, upgrades, repairs [ok, confess some pricey mods too ]
e92 M3 - Interlagos Blue | Recaro GTs w/Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II; SuperSprint config: non-resonated front+X-pipes+F1s; cat-less; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
