ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      04-06-2024, 03:52 PM   #1
dre99gsx
515
Drives: 1994 Toyota Supra
Bimmerworld E46 monoball RTAB failure
I seem to be the only breaking things lately..
I started to notice clunking in the rear, and after further inspection, found that my recently installed BW RTAB had some slop. The uniball/bearing they use had about 1mm in/out slop.
This was on the driver side, which is also the side that goes through wheel bearings.
Instead of raising this issue to BW, I decided to press out the balljoint and found a new rear upper control arm balljoint (part # 33306852895). I bought this part because BW's description states they use an "OEM balljoint".
So, I go to install it, and then realize it's about 9mm wider than the unit BW had used.
I have a press and widened the carrier to accept the wider bearing, but I need to source the other side just incase that one also fails.
Does anyone know the correct part number for this bearing? I will ask BW but thought I would ask here. The original part was a Meyle with blue rings. The replacement bearing I got was direct from BMW dealer, no brand markings on it.
And are these things known to fail? And what a PITA to remove it...
      04-07-2024, 05:59 PM   #2
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
Hadn’t heard of these failing. My Syncro Design RTAB’s are going strong for 6 years.
      04-08-2024, 04:15 AM   #3
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
ive got Turner monoball rtabs, but my carrier is completely different, as is the rear control arm.. they looked pretty nice quality. did you install them correctly as i know if you smash em in offset they tend to not go very long. I also remember that your rear diff had a heap of heat, possible heat transfer to the monoball?
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by
      04-08-2024, 02:45 PM   #4
dre99gsx
515
Bimmerworld says they use the bearings out of this part:
33322406292 E90 rear wishbone
Apparently the bearing isn't offered anywhere individually (at least I can't find it myself).
I installed this part way after I solved my rear diff heat issue with coolers. Never had any melted bushings back there since.
I was careful installing it as well.
That part is quite far from any heat generating source.
UPDATE: Looks like this is the part:
BMW Control Arm Ball Joint - Lemforder 3067901
45.2OD, 48mm length, 12.05ID
zpost
