07-21-2023, 06:50 AM | #1 |
970
Rep 2,436
SPL Parts Service Bulletin, Anyone ?......
Hey guys,
Who received this email from SPL? I got it a few days ago. Has anyone addressed this issue? Any failures on track regarding? https://www.splparts.com/tsb-2301/ |
07-22-2023, 10:32 PM | #2 |
11591
Rep 12,733
there was some discussion about it in the chit chat thread. i haven't seen anyone post any failures.
someone posted up about a possible failure at laguna seca about a year and a half ago, but the car was wrecked and several suspension arms were broken, some of which were oem. hard to theorize what actually happened.
Instagram; @roastbeefmike
07-23-2023, 06:48 AM | #3 | |
970
Rep 2,436
07-23-2023, 05:01 PM | #5 |
970
Rep 2,436
07-26-2023, 08:43 PM | #8 |
74
Rep 34
I live in Canada, and I have heard of few cars locally having the failure. It is scary, so I was able to buy the updated studs. I have since replaced the bolts which looked fine with the studs.
Instagram: prius_m3
07-27-2023, 07:58 AM | #9 | |
970
Rep 2,436
We shouldn’t have to buy anything if the part is prone to failure from the start and there is a Service Bulletin out. |
ronniem348.00 |
07-27-2023, 08:01 AM | #10 |
3992
Rep 3,411
It’s prone to failure if not properly seated and torqued to spec. Checking and confirming on a routine basis is what they’re requiring to prevent failure. I doubt they will be giving away replacement studs.
Not a Doctor, those are just my initials.
07-29-2023, 11:52 PM | #11 | |
74
Rep 34
Instagram: prius_m3
11-17-2023, 02:38 PM | #12 |
1112
Rep 1,085
SPL Stud Upgrade Alternative
I wanted to provide you with an update regarding the SPL service bulletin. The bulletin addresses issues with their previous bolt style, which tended to gall out due to insufficient torque, leading to infrequent but severe failures. As a precautionary measure, SPL has issued a service bulletin advising users to remove the bolts and inspect the threads for galling. If the bolts were torqued under 110 pounds, replacement is recommended due to fatigue.
Following the service bulletin guidelines, I removed and replaced my bolts with the new, albeit more expensive, stud design. However, the installation proved challenging (requiring 180LB of torque), and I'm uneasy about having a nut on both ends. Considering reverting to the old bolt design, I encountered a flaw: the bolts were only 4 inches long, and the threads were damaged by the jam nuts upon removal. To address this, a friend suggested a solution: using 4.5-inch-long, highest-grade ASTM A574 bolts with the addition of a spacer for increased articulation (see arrow). Use the same number of spacers you had before above the bearing. A robust Grade 8 nylon nut was chosen for one end, and the entire thread was treated with copper antiseize. Torquing to 124 pounds (lubricated torque) and marking with a paint marker completed the process. Routine checks, including inspecting the marker, are now part of my pre-track weekend routine. Black-Oxide Alloy Steel Socket Head Screw 5/8"-18 Thread Size, 4-1/2" Long ASTM A574 (equivalent to 12.9 grade) https://www.mcmaster.com/91251A489/ High-Strength Steel Nylon-Insert Locknut Grade 8, Zinc Yellow-Chromate Plated, 5/8"-18 Thread Size https://www.mcmaster.com/97135A275/ Service Bulletin: https://www.splparts.com/tsb-2301/ SPL Studs = $73 shipped (I don't love this design) My solution = $28 shipped, you can use these for other SPL arms and preventative every 3 track season. (proven SPL design, just longer and stronger bolts) *This is based on my research and experience with hardware. I'm not responsible for damage if you follow my method. These ASTM A574 are stronger than SPL's Grade 8 original style bolts, and it's longer for more thread count.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
ronniem348.00 |
11-20-2023, 03:56 PM | #13 | |
1567
Rep 672
kolosy1531.00 |
11-21-2023, 09:22 PM | #14 | |
1112
Rep 1,085
The previous SPL bolts are 4" Grade 8 bolts 1/2 drive 5/8 diameter, which I love the ease of install and didn't really have issues with other than it slightly bent after 1.5yrs with track use. I honestly would run the OG bolts again vs the new studs if I didn't find a stronger / longer bolts solutions. These are almost identical to the OG bolts but 4.5" long, Grade 12.9 (which is higher than grade 8), 1/2 drive 5/8 diameter. The OG bolts worked just fine, some reported bending and very rare reported breaking due to under torqued. The solution I'm providing to the community is just the OG exact design, but stronger and longer to accommodate nylon lock thread nut. Part of the OG bolts failure was the jam nuts galling the treads, causing a weak point. Just to give you an idea, these 12.9 grade are at 170,000 psi tensile strength. 12.9 grade are in the same class as MSI and high end racing wheel studs. I'm not reinventing what SPL did, I just found a better and stronger solution. I love the SPL OG bolts design, I don't love the new studs design that I installed and threw it away after 3 weeks. These 4.5" 12.9 grade bolts already used and proven on track on the SPL LCA. You're saying the obvious, of course with any mods, do it at your own risk. If you take a modified car on the race track and you had a bad day due to parts failure, good luck pointing the blame on the suspension part manufacturer. That's what track insurance is for. Regarding McMaster-Carr. See photos below of the 4" black oxide 12.9 grade vs SPL OG 4" stainless grade 8. I doubt SPL makes their bolts in house as that requires a steel foundry etc, they most likely outsource and there's not too many bolts manufacturers in the world. McMaster-Carr is just a supplier.
ronniem348.00 |
11-21-2023, 10:50 PM | #15 |
11591
Rep 12,733
i don't see what the difference is between the stud spl is suggesting and using 12.9 hardware... maybe i'll shoot them an email.
11-21-2023, 11:19 PM | #16 | |
1112
Rep 1,085
"Description of Issue: SPL has received inquiries regarding bending and failures of cap bolts used in SPL front lower control arms. Information supplied to SPL indicates inadequate or un-retained torque of retaining nut/bolt to lower control arm may be contributing to bending and fatigue of grade-8 fasteners." I have no issues with their OG style Grade 8 bolts, other than slight bend after 1.5yrs tracking and the thread are galled from jam nuts. All I did is upgraded to 12.9 (ASTM A574) and longer so I could use a nylon lock bolts. That fixes both issues: Grade 8 bolts bending and jam nuts galling the threads. I'm sure the studs are fine, but I don't like them and threw them away after 3 weeks on my car. Just for the record, I like SPL's products and services. Hell, I have every single SPL part number on my car. I just wanted to source better mounting hardware than what they had for ease of install and pre-track inspection.
