03-29-2023, 12:34 AM | #1 |
14
Rep 60
2011 M3 ZHP | DCT | 96k miles (Rod bearings replaced) | Suspension and Brake Mods
2011 E92 M3, DCT, Comp package. ~96,500 miles with rod bearings replaced by Lang Racing in Feb. 2021 at 87k miles. Alpine White with Fox Red Interior Asking for $38,000 Mods And Preventative Service 1. Rod Bearing and Engine Mounts at Lang Racing - February 2, 2021 (87,179 miles) 2. Ohlin Road & Track Coilovers with EDC delete with approximately 9k miles 3. Vorshlag Camber plates (installed same time as coilovers) 4. Turner adjustable rear toe arms 5. Monoball bushings in front control arms 6. Stoptech Trophy Big Brake System with PFC-08 pads and original Stoptech pads (Only about 1.5k miles, essentially brand new) 7. Full paint correction and two layers of Carpro ceramic coating done in Decemeber 2021 and topcoat reapplied every 6 months. 8. Transmission fluid flushed at 53k miles and 93k miles. 9. Installed New Battery in July 2022 Service History 1. January 15, 2018 (53,000 miles) Spark plug change 2. January 15, 2018 (53,000 miles) transmission fluid flush 3. January 15, 2018 (53,000 miles) oil change 4. July 26, 2019 brake pad, brake rotor change, brake fluid flush 5. March 6, 2020 Full interior detail including applying Leatherique to all leather surfaces to rejuvenate and condition leather 6. August 27, 2020 stainless steel brake lines, brake fluid flush, power steering fluid flush 7. December 26, 2020 air filter (K&N High performance), spark plugs replaced 8. February 2, 2021 (87,179 miles) Rod bearing change/Oil pan change/Engine Mount replaced 9. February 11, 2021 (87,389) Recall Repair Positive Batter Cable, Recall repair Blower Motor Wiring 10. August 13, 2021 coolant flush, Ohlin R&T Coilovers, Vorshlag camber plates 11. August 15, 2021 (90,000 miles) brake fluid flush 12. September 25, 2021 (90,500 miles) cabin filter replacement 13. October 12, 2021 (90,500 miles) BMW Manifold Differential Pressure Sensor replacement 14. October 15, 2021 (90,500 miles) New brake pads Textar 15. January 8, 2022 paint correction and ceramic coating (CarPro cQuartz 2 coats) + CarPro Gliss top coat 16. January 11, 2022 tire change - Advan Apex V601 17. February 9, 2022 new carpets 18. February 18, 2022 (92,688 miles) Coolant flush. Changed water pump and thermostat preventively. 19. March 31, 2022 installed Turner rear adjustable toe arms 20. May 15, 2022 (93,400 miles) Transmission fluid flush and filter replacement. 21. July 12, 2022 - install new battery 22. August 23, 2022 (94,000) Reapply top coat 23. October 3, 2022 Stoptech trophy BBK with PFC 08 pads, installed monoball bushings in front control arms, corner balanced car 24. February 10, 2023 Full interior detail 25. Oil and filter change every 5,000 miles Liqui Moly/Genuine BMW I posted previously without pics but reposting again with pictures. (LA rain made it hard to take photos). Last edited by Emveee; 04-05-2023 at 03:37 PM.. Reason: Added "or best offer" |
03-30-2023, 03:11 AM | #2 |
14
Rep 60
Update: I ran a carfax report that shows no accidents or other issues with the car. Can provide a copy of the carfax if you DM me.
S65e92///m336.00 |
04-05-2023, 01:46 PM | #4 |
Rep 1
Almost the one
Emvee is a great seller to work with and I got very close to buying this one, but went with something still stock. I called all the shops that have worked on the M3 and they spoke very highly of the car and quality of parts. Great car for the right buyer!
Emveee14.00 |
04-05-2023, 04:23 PM | #6 |
14
Rep 60
CravingBavaria312.00 MMMM6GC275.00 |
04-05-2023, 04:33 PM | #7 |
312
Rep 420
Drives: 2011 BMW E92 M3 ZCP
Thank you!! Swift Spec-R Springs only! I want your brakes
04-05-2023, 05:30 PM | #8 |
14
Rep 60
CravingBavaria312.00 |
