12-08-2022, 12:15 PM | #1 |
243
Rep 223
Spring, shock and swaybar question
Need some help here……
My E90 is currently on the stock chassi except for H&R lowering springs. The plan is to install Eibach B8’s with H&R swaybars. So my question to all the chassi gurus is basically if I run the combo of the shorter body length B8’s with H&R lowering spings and H&R swaybars, do I need adjustable swaybar links to compensate for the shorter body length of the B8’s? Appreciate any guidance! Thanks, J.
2010 E90 M3
2013 F31 328i Touring M Performance |
12-08-2022, 04:29 PM | #2 |
YNWA
1053
Rep 815
I would say no because I don't believe that the body of the B8 is shorter than stock. The shaft and internals are what is "shortened". More specifically, what would matter to you is the distance between the swaybar link tab (or "ear") on the shock body to the hub/clamp. I believe it's the same between stock and bilstein (b6 or b8).
I know for a fact this was true on E46 M3. I'll attach a pic of b8 damper next to factory strut, and you'll see they're the same dimension (except for the bottom portion that protrudes down, out the hub clamshell which is irrelevant).
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 Last edited by TboneS54; 12-08-2022 at 04:34 PM.. |
12-10-2022, 09:13 AM | #4 |
243
Rep 223
Thanks guys for the valuable imput! Are the stock swaybar links strong enough to cope with the larger diameter H&R swaybars?
2010 E90 M3
12-10-2022, 09:23 PM | #5 |
11591
Rep 12,733
its going to depend on ride height, as well as the tab location on the struts. the oem swaybar is fine, but maybe have some adjustable links on hand to be prepared for the install.
Instagram; @roastbeefmike
12-13-2022, 03:29 AM | #6 |
243
Rep 223
So with the car lowered approx 1-1.25" from stock, should I be looking at longer or shorter adjustable links and what lengths should I be looking for?
2010 E90 M3
12-13-2022, 07:52 AM | #7 |
11591
Rep 12,733
its all going to depend on your ride height and where the mounting tab is on the shock body. i don't know what it would be for this particular setup. it is probably not an uncommon setup, so hopefully someone chimes in with better insight.
12-13-2022, 09:52 AM | #8 |
243
Rep 223
2010 E90 M3
