03-14-2022, 01:16 PM | #1 |
Bud Light General
132
Rep 402
Blackvue Dashcam Install Atlanta GA
Hi all,
I recently purchased a Blackvue 900X plus 2 channel with the BlackVue B-124 battery for my 2019 M4 CS. I have done some research and understand the general idea for the installation but I could use some help. Are there any forum members in the Gwinnett/Atlanta area that has some experience and can lend a hand? I do not mind paying for the time as well! I was also looking for some professional installers in the area but having a hard time finding a reputable source and would much rather be a part of the process! Thanks everyone! |
03-24-2022, 12:00 PM | #2 |
475
Rep 628
Were you able to get this installed? I’m not in the area but my F80 has a similar setup with a 900S-2ch and a cellink battery so I should be able to answer any questions you might have.
03-25-2022, 12:52 AM | #4 |
Bud Light General
132
Rep 402
Thanks for the help guys!
I finished routing the wiring from the front to the rear camera and to the trunk box. All I have left to do is the fuse box. I do not have much experience dealing with fuses but I think I have a general idea. I am following a post from another user on here. I was planning on hooking up my 124 battery to one of the fuses circled in the pic below. Per the other users post these appear to be only on with the ignition and off when car is turned off (which is what I am looking for). https://f30.bimmerpost.com/forums/sh....php?t=1575292 Does it matter which one I tap into of the three? And do these serve any function in a f82 M4 CS? I also need to have ground, can I unscrew the circled bolt and put ground there and tighten it down? I believe after this I can crimp the wire and complete installation. I am a novice so please forgive the questions! Thanks for the tips! |
03-25-2022, 06:18 PM | #5 |
29
Rep 37
Ground is good, using it for my meth pump. Not sure on fuse but it’s easy enough to tap it and see that it comes on and turns off correctly, can’t hurt anything testing it.
03-27-2022, 04:08 PM | #6 | |
271
Rep 326
As for the ground that's what I did as well; I used one of the screws that fastens the fuse box in place and sandwhich the crimp connector in between the car frame and fuse box, it works. Don't recall what amp fuse I used, I might of used a 10a or 15a. Refer to the 124 battery manual for current draw. The BMW genuine oem double leaf contact connector with wire can also be had in Ebay. https://www.ebay.com/itm/31343979087...QAAOSwndFeF4hY |
