R44 Performance
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Members Classifieds > Wash / Wax / Detailing / Touchup Supplies
      10-10-2021, 03:28 PM   #1
ptper
589
Drives: '18 Avus Blue F80
Metro Vac Blowout Combo Special!!
BIMMERPOST / Classifieds
Asking Price:
USD 300.00
Item Interest
Sorry couldn't help myself...Prefer local pickup. Will ship at buyers expense.
Metro Vac 'N' Blow Vacuum Cleaner VNB-4AFBR - (includes Wall Mount) + Metro Vac Metro Vac Air Force Blaster Side Kick (No Accessories)
Also, will throw in some extra foam filters and vacuum bags.
https://www.ebay.com/itm/144240718337
This twin fan 4 peak horsepower vacuum is the most powerful car vacuum ever tested. It has an amazing 95" of water lift (the standard measure for a vacuum's efficiency). Compact, powerful, portable, it's heavy-duty lightweight all-steel body is only 17" long and 7" in diameter which makes it easy to handle. Use it off road, too, as a vacuum for cleaning around the house or yard, or as a blower to inflate rafts, air mattresses or blow away leaves. On road or off, Vac N Blo; offers the versatility you need. It comes fully equipped with a wide range of attachments, so whether the job calls for power or precision, you'll have the right tool at hand. A 6 ft flexible hose plus two 20" extensions reach even the furthest corners. Other attachments include: an upholstery tool, dust brush, crevice tool, blower nozzle, air mattress inflator, shoulder strap plus 4 "detailing" attachments to get into tiny spaces.
Vac'N Blo Features:
- Construction: All Steel, Made in USA
- Motor: 4.0 HP, 95" Lift
- Volts: 120 V, 11 amps, 12 ft. Extension Cord
- Decibels: 73-77
- Hose: 6 ft. Flexible Hose, (2) 20" Extensions
- Filter: Reusable Dust Cloth Bag
- Attachments: Upholstery Tool, Dust Brush, Crevice Tool, Blower Nozzle, Air Mattress Inflator, Shoulder Strap, 4 Mini "Detailing" Attachments.
Metro Vac Metro Vac Air Force Blaster Side Kick (No accessories)
https://www.ebay.com/itm/144240725176
Dry your car or motorcycle in minutes with warm (30 degrees F above ambient), dry, filtered air generated by this handheld powerhouse. Getting a professional quality, dry finish for your ride has never been easier than it is with the Air ForceŽ BlasterŽ Sidekick™! It is the perfect way to expel water from side-view mirrors, door jams, body seams, grills, lights, engine and more. The Sidekick™ dryer does it all!
The all-steel construction of the Air ForceŽ BlasterŽ Sidekick™ makes it nearly indestructible, yet it only weighs about three pounds. Don’t be fooled though, this lightweight car dryer packs a powerful 1.3 HP motor and single-stage fan that moves 18,000 feet of air per minute. Its portable size means the Sidekick™ delivers powerful drying results without straining your muscles.
The Sidekick™ features a 14-inch heavy-duty power cord, durable neoprene nozzle and air-flare, as well as an EZ Change foam filter.
Best of all, this high-performance car and motorcycle dryer is designed to save you time and get your pristine ride back on the road in no time.
BlasterŽ SideKick™ SK-1
Construction: Sturdy All Steel
Motor: 1.3 Peak HP
Amps: 8 Amps
Watts: 960 Watts
Airflow: CFM/FPM 18,000 ft./min.
Cord: 12", 3-Conductor
Dimensions/Weight: 4.25"x7.5"x9.75" / 3 lbs
      10-21-2021, 08:50 PM   #2
RElias21
RElias21's Avatar
563
Drives: 2017 30 Jahre M3
Willing to separate?
Previously:
2010 E92 335 (6MT)
2011 E92 M3 ZCP (6MT)
      10-21-2021, 08:54 PM   #3
9M71
1234
Drives: 2018 F80 M3 | 6MT
Too bad you were not closer to NYC otherwise I would take it.
      10-22-2021, 07:25 AM   #4
ptper
589
Yes, which one were you interested in?
I can ship it to NYC if we can work out the shipping costs.
      10-22-2021, 09:51 AM   #5
9M71
1234
Sent you a PM
      10-22-2021, 10:22 AM   #6
ptper
589
Sent you a PM
Looks like your mailbox is full. Can't follow up to your last question.
      10-22-2021, 10:24 AM   #7
9M71
1234
Sent you a PM
Just cleared inbox
      10-22-2021, 10:28 AM   #8
ptper
589
Just cleared inbox
responded.
      10-30-2021, 09:09 AM   #9
ptper
589
Bump
f80post
