09-19-2021, 04:53 PM | #1 |
Rep 68
Soft pedal
Last track day the organizer threw the checkered about half way through the lap, so we only got a very short cool down. Aside from pad deposits (see other threads), the pedal felt consistent throughout the 20 minute sessions. After a session which had very little traffic, I drove around the paddock for ~5 minutes to try and make up for the very short cool down lap. Ended up having the pedal go to the floor as I coasted into my parking spot in the paddock.
I assume this was heat soak from the calipers which caused the fluid to boil after the session? Also, what warning signs should we get on track that the fluid is getting hot...i.e. softer pedal? And, are there any other mechanical points of failure in the system to be aware of? Fluid was a premium track-capable fluid per the shop...probably don't see many track cars at that shop. |
09-19-2021, 05:43 PM | #2 |
1863
Rep 893
I'm assuming you're on stock brakes and castrol SRF or some equivalent. There have been a few who have had some success with modified stock systems in cooler temps, but the vast majority of folks tracking with the stock system experience what you did. My pedal went 1/2 way to the floor my first track day at Laguna. These are heavy cars with mediocre brakes. They are fine for a couple hard stops on the street, but won't hold up to 20 minute sessions on the track. I view the BBK as a safety item for tracking this car.
It doesn't really make sense, in my opinion, to chew through the stock system and keep replacing it. My vote is for the Essex AP kit.
Instagram: slcook54
09-19-2021, 06:52 PM | #3 |
Rep 68
Did you get some warning signs that the pedal was getting softer?
I was on track pads with a fluid that probably wasn't up to the the task. My question basically is if the OEM system with track pads and fresh track fluid will at least give warning of either pad or fluid issues or if others have experienced a cliff. |
09-19-2021, 07:47 PM | #4 |
11591
Rep 12,733
the oem system is garbage. the warning signs will be a gradually softer pedal. the depth of the press may be gradual, so don't let that fool you until its too late. its gradual, but once the fluid is boiled, its going to feel "all of the sudden." if you're going to limp along an oem brake system, you need to include some cool down laps and significant time rolling around the paddock if the session is stopped abrubtly.
Instagram; @roastbeefmike
09-19-2021, 10:58 PM | #5 | |
75
Rep 388
1. It was probably shyte fluid. 2. You shouldn't use that shop. Better: You bring Castrol SRF and specify your fluid. Don't let a shop without concrete and current track credentials use mystery fluids, pads or components on a tracked car. Your system needs a full flush now. Full. Recommendation: Once you see a checkered flag - go "no brakes" and manage your speed to the next turn. That doesn't mean crawl. Which pads are you using? |
09-20-2021, 01:35 AM | #6 |
11591
Rep 12,733
all brake fluid is track capable. just depends on how many minutes you want it to be capable for.
09-20-2021, 11:50 AM | #7 | |
Stop the hate, get a V8
3853
Rep 8,625
I would agree with this assessment. And yes, as the fluid gets hot you will notice longer pedal travel during the session. The stock brakes don't have a ton of cooling so as you get faster (and run stickier tires), you will need to manage your brakes a bit. A BBK will provide a lot more endurance, lighter weight, and faster pad changes. It might even drive consumption costs down a bit over time. Not having to worry about your brakes every time you approach a braking zone will make track days much more fun.
Past: 2011.5 M3 sedan ZCP |
09-29-2021, 07:18 PM | #9 | |
48
Rep 98
09-29-2021, 09:08 PM | #10 |
3956
Rep 3,994
I've done flushes after a few shops supposedly did them.
Guess what, most of them lied, or barely did anything (few quick bleeds, then top off). Learn to do it yourself. Vacuum or suction out the reservoir with a syringe and thoroughly flush each line. You'll go through atleast 1L if you did it right. I use cheap ate200 fluid, fresh for every track day without issue, yet a few guys that supposedly have SRF fluid have had brake issues on track days with me. Plus they run slower laptimes. One melted a caliper piston. I showed one guy what his fluid looked like and there was no way it was done properly before his track day. Last edited by tdott; 09-29-2021 at 09:14 PM.. |
09-29-2021, 11:35 PM | #11 | |
5356
Rep 2,806
Drives: '09 E90 M3 - IB
For me, putting fresh brake fluid every track day is just not practical. I can leave SRF in the system for a year without issue. I never have a soft pedal. Of course, I also give credit to the AP kit for being able to dissipate heat quite efficiently.
slcook541863.00 |
09-30-2021, 11:03 AM | #12 | |
3956
Rep 3,994
Since you are tracking often enough and using a high quality fluid you shouldn't have any problem doing a less than full flushes, I'm sure your fluid is staying fresh enough. My comments were more towards those who are new to tracking, if the car hasn't gone through much maintenance and the brake fluid is probably several years old. Then they take it to a local garage, chances are pretty low they are going to get a really well done flush. Now that is not to say there aren't a few good shops out there that I'm sure can be trusted to do a good job. It's just I worked in the industry and I know the short cuts the mechanics will take when they are getting paid flat rate. A friend I made recently had this happen, he provided SRF to a shop that did his prep before his track day which we attended together, his car is stock except for wider wheels/tires and lowering springs, even his exhaust was still stock. Yet he over heated his brakes at Sebring (pretty hard on brakes) warped brand new FCP rotors new from a few weeks before and had soft pedal issues. It wasn't a pad deposit issue. There was still a lot of vibrations under braking after re-bedding and hard stops after the track day and it got worse. Since we became friends, I helped him install new rotors/pads as they were covered from fcp and did a brake fluid flush with SRF. What came out was certainly not fresh fluid. I even made sure we did the DSC activation/bleed procedure using ISTA. That takes time and unless a shop is charging you 1-2 hours of labor I doubt they are doing it fully. He went on to do two track days after that and his brakes held up much better.
09-30-2021, 01:07 PM | #13 | |
5356
Rep 2,806
10-04-2021, 09:02 PM | #14 |
1258
Rep 2,492
2010 E92 M3 DCT
