07-11-2021, 06:12 PM | #1 |
13
Rep 19
Seat wear leatherique before and after.
Got myself a 15 M4 with 73,000 miles. The M was very well taken car of but there is some wear on the drivers seat. What do you guys suggest to remedy this.
Thanks Steve Last edited by Skenseth; 07-18-2021 at 12:55 PM.. |
07-11-2021, 08:50 PM | #3 |
Racecar Driver
1288
Rep 1,955
Drives: BMW M4
There are professional leather repair places, just vet them carefully. In the future to prevent this, it will determine how you get in and out of your car.
I find the best way to get in and out of a car is like this: Getting In Open the door and sit on the seat first. Turn your body in and bring in one foot at a time. Getting out Open the door and turn your body to get your legs out first. Prop your self up on the door sill and push your self out/stand up. This helps prevent additional wear and tear on the bolster when you get in and out. https://www.youtube.com/watch?v=5ST3ygfg28s I learned this from my last car as it was really low to the ground.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
07-11-2021, 10:13 PM | #4 | ||
MDOC
43
Rep 57
Your best bet is to drop by your local dealer and find out who they use for leather repairs. They won't use someone unless they're happy with the results.
MDOC
07-12-2021, 05:25 AM | #5 |
62
Rep 132
F80 M3 Comp in Sakhir Orange
07-12-2021, 09:55 PM | #6 |
151
Rep 548
+ 1 Colourlock
Leatherique is another option. Perfect timing…if you apply and leave it out in the heat & humidity, you will get better results. Only issue is that it takes time. |
07-18-2021, 09:47 AM | #7 |
13
Rep 19
I used Leatherique. Worked very well, the only problem is it reviled the wear on the center arm rest. Most likely going to get a new one from FCP but was wondering if any of you have a slip on cover you like to protect yours from this very thing. Before, after, arm rest.
07-18-2021, 08:15 PM | #8 | ||
151
Rep 548
Nice! I go back & forth with Colourlock and Leatherique…both great products. You can probably find a used one at a relatively inexpensive ask. I don't plan to sell mine but know many others have swapped the leather for the Alcantara/CF option. Post a "WTB" in the applicable forum & I am sure you will have some luck. |
07-19-2021, 04:38 PM | #9 |
251
Rep 631
Drives: 2014 M6 Grand Coupe CP
Skenseth, how on earth did you mange to avoid dying the stitching? Seat bolsters came out nicely.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
07-19-2021, 07:07 PM | #10 |
13
Rep 19
The leatherique isn't a dye. It's a two part deep cleaning product. It was a good bit of work but we'll worth it. Check it out on YouTube. If it didn't turn out as good as it did I was going to try colourlock. I'm happy with the results.
10-08-2021, 04:28 PM | #11 |
277
Rep 558
I have black leather and my bolster looks exactly the same. That's how I bought it. It hasn't gotten any worse in the 25,000 miles since I bought it because I've kept up with the Leatherique. Sometimes I just apply it to that one section and put some seran wrap over it and let it soak for a while. It's great stuff, but it's not a permanent solution to the bolster wear.
2017 F80 ZCP - Mineral Grey Metallic
11-08-2021, 08:33 PM | #12 | ||
151
Rep 548
I would strongly recommend using Colourlock Leather Shield on the bolsters now. It's a terrific product and will likely prevent you from having to go back to Leatherique down the road. |
11-11-2021, 08:47 AM | #13 |
I Rock Your Girls Box
293
Rep 662
Its a car dude... if you don't want any seat scuffs... don't buy used, and never drive the car. Tutorials on how to get in and out of ones car.... really?!! You need to view your seats as a wear item, and you can only help prevent/delay wear to them with proper maintenance from day 1 - or keep your car as a garage queen.
On another note.. you either have to pay for a full repair, or you can apply a conditioner like Leather Masters to the areas affected most; pair this with a monthly cleaning/conditioning to prevent further scuffing. Ensure the seats are free of debris and small gritty bits before cleaning - not doing this will cause micro scuffs on the leathers surface = further damage. |
11-11-2021, 09:29 AM | #14 |
5460
Rep 5,153
Colourlock spirit and leather fresh come next to complete your repair. Read up here:
https://www.colourlock.com/tip/car-l...r-damages.html
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
01-07-2022, 05:44 PM | #15 |
Rep 17
I noticed the side bolster was really pronounced when I got my M4 and anticipated accelerated wear on this part of the seat.
To prevent this from happening and to help me get out of the car (I'm tall), I put my hand down on the rocker panel. I lift up from my feet (one in and one outside) and hand to avoid compressing the bolster. Wear has been minimal this way. If you repair the wear, it will be made worse again by leaning into it during egress. |
05-24-2022, 07:02 PM | #17 | |
133
Rep 831
05-25-2022, 07:44 AM | #18 |
293
Rep 662
Just remember, this is just like a girl who wears too much makeup. Eventually you will wake up to that fuggly chick one day, once the product wears off.
Conditioning the seats is simply a cover-up, and considered temporary, so you will want to keep up with regular maintenance. |
