04-29-2021, 11:27 AM | #1 |
522
Rep 629
X35d Transmission Saga (Full Replacement)
Figured I'd post this since these things are getting up there in mileage. Some of this might be useful to someone in the future. And any input for those who have done this or similar work is always welcome. Not sure how many would be "adventurous" enough (read: cheap enough) to undertake this on their own. This is not a DIY, more of a chronicling. I have not done this before on an X5d, and so far, this has taken place over about 3 weekends.
First, the backstory. On the highway trans would slip out of gear reporting 4f85 and/or 4f89 for 3-4 gear ratio monitoring. Happened 3 times in a 6 month period, every time when cruising in 6th and requesting a gear drop for a pass. Pull over, restart, and can drive away. But the last time was the last straw as this was the wife's ride and I don't want her to feel unsafe. Took it off the road February 2020. During 2020 I threw a hail mary (or 4) and had the valve body rebuilt and serviced the trans with seals/pan/multiple fluid flushes. Below are some shots of that, including the original fluid @ 166,000 miles. Threw the rebuilt VB in and had the same results. I was taking a path of least resistance approach so I was not overly surprised or disappointed that the VB and trans service did not work. The company who rebuilt it for me warned me it was likely the E clutch bearing/bushing that had failed inside the trans with those codes presenting. Figured if I needed a "new" trans I'd throw the rebuilt VB in anyway as it would be good preventative maintenance on the younger unit. BTW, I tried 4 fluids, Pentosin, Liqui Moly, Redline, and Valvoline Maxlife.. Only one that would get the transmission back into 4th gear was Valvoline Maxlife Multivehicle ATF. Uncoincidentally, it's also the thickest of the fluids. The gear change was not smooth though and after 4 or 5 changes would eventually trans failsafe. So I left it parked and we drove our other Bimmers, fast forward to 12/2020 and I scored a suitable 88000 mile (verified) trans off of Ebay. $800 shipped. Not the prettiest thing in the world, but it should do nicely. 03/08/2021 Work begins. Spent about 10 hours on it the first weekend with a buddy. Was unprepared for how much extra work the diesel model brings with it. Made some good progress and then hit a major blockage. But it was 1:30AM at time of blockage so I called it for the day. So far:
So we stopped when we realized the access panel for the flywheel bolts is blocked by the DPF. The BMW TIS procedure is laughable when they mention "setting the DPF to the side." There is literally ZERO room to access the 10mm bolt holding the access panel in. And even if you could get it out (we broke it loose) you would have no access to your flywheel bolts. It was at this point I realized this was going to be A LOT of work. And that I never wanted to do it again. So, the preventative maintenance ordering began. Ordered, exhaust gaskets, engine mounts, rear main seal, transfer case mount, all vacuum lines, pressure converters, and a new fuel filter. 03/22/2021 Work continues. Some notes and accomplishments.
A trans jack would be very helpful, I am buying one before putting the new trans in. We got it out with a floor jack and long adjustable cross support bar that we strapped the trans to. But that was less than ideal, multiple instances of us having to bench press the trans and/or Xfer case. They're heavy. I'm sure I'm forgetting stuff, but I'll add it as I remember. I blocked it out from my head and took Sunday off mentally. Didn't even clean up the tools/area. Will do that this week in prep for swapping over the transfer case and mechatronics unit. Here are some pics of the progress. Smurf massacre. So. Much. Blue. See that crossbar in the foreground? That thing can rot in hell! 04/17/2021 Work continues. We spent all of Saturday on it. A good 16 hours... I know, I know, we're working slow as molasses creeps. Well, we're doing it all on our backs, and there's a bunch of "while we're in there" going on too. So that's my excuse. I'm slow, I've made peace with it. Had to make a couple of tool and fluid runs too, so time management could have been better.
Some pics: I think that mount is supposed to be attached in there? I was in a hurry when I bought this mount so ended up getting a "Power Torque" mount from O'Reillys. LoL, I have no experience with Power Torque so went ahead and dumped a bunch of gasket maker into it just for good "feels." No matter how bad the pookie filled Power Torque bushing is, it's better than the torn one that was in there. The bearing press tool I bought at Harbor Freight didn't have the exact right cup size for the bushing so a roll of Gorilla Tape filled in nicely. Worked like a charm and took about 10 seconds to install. Old transmission after pulling the mechatronics/valve body out. Here's a shot of the back of the motor after pulling the flywheel and old RMS. Took the shot for the info on the back of the block for S's and G's as I don't ever plan on being able to see that sticker so clearly again. Now that everything is "installation is the reverse of removal" hopefully things will go a little quicker. Going to loosen the steering rack and really drop the subframe this time though so that the DPF and engine mount arm goes in easier. It was not fun wiggling those out. 04/23/2021 Got my DPF back from being cleaned by a diesel truck outfit in Austin. One day turnaround. They said it's one of the cleanest ones they've ever seen regardless of mileage and that the truck must be a well taken care of example. This x5 is at 166,000 miles and 30,000+ under our ownership. Told him previous owner was a dealer who would drive it between Texas and Louisiana so my guess is that the regenerations have always been regular as we don't do any regular short trips in it either. He agreed that sounded right. Usually DPFs are flow tested but for the Euro ones they get they aren't setup for air flow testing so instead weigh each unit before and after. They usually do commercial semis and fleets as you can imagine. Actually took me 5 calls before I could find someone to clean this thing. Sheet says they pulled out 56g of soot/ash. More importantly for me as this was done as preventative maintenance is that the DPF got a clean bill of health and will not EVER need to come out again in my ownership. At $400+tax this is cheap compared to a new $2400+tax unit. The honeycomb element was visibly cleaner which is nice too. I had to separate the SCR injection tube from the DPF flex pipe and all the sensors before giving the DPF over for cleaning. Posting this picture to show that we had bent the 2 EGT sensors up a bit during the removal process. I ohmed them and both are similar at ~14.6K ohms so I bent them back carefully/slowly and ohmed them again. Still reading where they were before and both are close so hopefully I didn't bork those up. @ $65/ea it would just add to the cost... which I will tally up fully later. That brings us up to current. Hoping to get a lot done on it this weekend but our plumbing decided to act up so I might be running a camera and auger in the sewer lines instead. It's always something. |
04-29-2021, 01:01 PM | #2 |
10
Rep 63
Wow, our X5 is creeping up towards your mileage, that doesn't look like a fun job at all and will not be looking forward to doing that. Nicely done with the blogging of your adventures.
Pheonix Yellow e46m3
Melbourne Red e93m3 |
04-29-2021, 03:09 PM | #3 |
729
Rep 1,728
Well done! This is a pretty invasive job
Do you think not having the trans previously serviced (original fluid166k) may have caused this failure?
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
04-29-2021, 03:41 PM | #4 |
277
Rep 1,055
Wow! Nice work! I can't imagine putting the dpf back in after all that work you did but to each their own. Great to see someone not messing around and just "doing it" while your in there too
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
04-30-2021, 10:36 AM | #5 | |||
522
Rep 629
With jobs like this I tend to do as much preventative maintenance as possible. I don't want to be back under the truck touching things I've already touched if I can avoid it. It drives up the cost of making repairs a bit but I find it greatly improves the reliability of my Bimmers. Worth the peace of mind IMO. |
RL18276.50 |
04-30-2021, 03:24 PM | #6 | |
277
Rep 1,055
Me on the other hand can't help myself and since one of my first vehicles was a 7.3L super duty, I don't mind the diesel smell at all. The ammonia smell though, that gets to me lol.
05-06-2021, 02:42 PM | #7 |
522
Rep 629
Trudging along here all. Got a couple of hours work on it Tuesday. I got the flywheel bolts torqued up. Also got the DPF back in the truck and loosely mounted (still have to install engine arm and mount so need play). That was a big accomplishment. Much easier than getting it out. I unbolted the steering rack and let it hover so I was able to lower the subframe another inch or so. That made a HUGE difference and gave me necessary clearance. Needed to employ the wife for a minute or two on the 4' pry bar while I maneuvered the DPF in. But was much easier going in than coming out.
04/04/2021 Some notes:
You can see one of the flywheel bolts through the access panel. A couple of shots of the new RHS motor mount versus a new mount. Had not completely failed, but definitely had some droop to it. Going to put another couple of hours into it today so look for an update in the next few days. Can't wait to get this thing back on its motor mounts and the subframe back in so I can move the engine hoist and jacks out of the way. |
05-11-2021, 09:37 AM | #9 |
1192
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
This thread made me realize Crystal Works is a masochist . No way I would undertake this without a lift.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
05-11-2021, 11:02 AM | #10 | |
522
Rep 629
Here's me after finally getting the old transmission out. I think it was 2AM |
blue dragon1191.50 |
05-12-2021, 11:30 AM | #11 |
522
Rep 629
Got some more work done on Monday. Put in about 3 hours doing various things.
Finished the fuel filter install. That was an ordeal that I had started on Saturday because the 5" rubber line that U-turns after the filter was cracked and started leaking after I had disturbed it. "No problem" I thought. I'll run to O'Reilly and pick up a small piece of fuel line. Nope, nothing will make that radius without kinking. Ugh, guess I'll have to pick up that piece from BMW. $85 later I had it as they do not sell the rubber portion separately. You have to buy the whole plastic piece too. Also got the motor mount arm reinstalled and both new motor mounts in place. The engine can now rest on its own mounts for the first time in a couple of months. Haven't torqued anything yet as I anticipate having to move things around a bit while trying to get the EGR cooler and sensors back in place on the DPF. That should be fun... 05/10/2021
I think Continental custom makes that small fuel line in that shape using a form. I could not get anything to make that radius. This shows condition of LS motor mount. Not failed, but like the other side, has some obvious droop to it. This is the steering shaft that you have to be wary of when lowering the subframe. You don't want to damage the seal that that shaft rides in or you will have a power steering fluid leak. Best to undo the steering rack (4 hard to reach nuts/bolts) so you can limit the amount the rack drops. You can see all my pink torque markings on the fasteners that have been done. Still need to torque the arm down, the one bolt behind the DPF is an absolute PITA to get to. Should be fun trying to get a torque wrench on that. |
05-27-2021, 12:35 PM | #12 |
522
Rep 629
With a summer trip/family reunion coming up wife has been working crazy hours, which means I put in OT with the munchkins so the truck progress has slowed. It's being made, just slower, only able to put in a couple of hours a few days a week after the kids go down. Will update when I have a chance.
But I did make this video with the DPF cleaning results for anyone interested. Ours turned out pretty clean so not sure the $400 was well spent, but I don't regret it just for the clean bill of health it got. As I've said, this is the last time I'm going this deep on the truck so that sucker is staying there now that it's bolted back in and torqued. 166000 Mile DPF Cleaning Results |
06-02-2021, 07:09 PM | #13 |
522
Rep 629
Still trudging along. A couple of hours a day here or there. Only support left on the drivetrain is the trans jack as I prepare to reinstall the Xmember for the Xfer case. Some accomplishments and tribulations:
05/17/20201-06/01/2021
06-10-2021, 05:24 PM | #15 |
1416
Rep 1,564
Congrats on the rebuild and respect for all of your work you did! I have 170K on mine (ZF8HP) and unfortunately it had issues already when I bought it over 80K miles ago. I have nursed it along with new solenoids which made it usable again some 40k miles ago but I know soon I will have to bite the bullet and pull it for a complete rebuild.
Its a real shame BMW lies about the lifetime oil. I think the ZF's could easily get 300K+ miles out of them were if not for that B.S. and oil changes were done at normal intervals. |
07-05-2021, 02:59 PM | #16 | |
522
Rep 629
I will update this with the final repairs/maintenance that got finished the project off eventually. The X5d drives amazing but I am currently working on getting ISTA running so I can work through the SCR repair plan. I neglected to do a reset of the NOX/SCR system before putting real mileage on the truck and it got pissed and threw an SCR efficiency code. I proceeded to make a second blunder and just reset that code... which triggered the 250 miles to countdown series of codes after about an additional 75 miles of driving. So I went on vacation with the family in the F15 and will now proceed to work on that. I am guessing it is going to want two new NOX sensors, a drain of the DEF system, and running through the test plan until it's happy again. What's another $700 in sensors? So much for feeling like I got a deal on the $800 trans! |
07-06-2021, 04:37 PM | #18 | |
522
Rep 629
Other than the above, not had a problem until now with the "Incorrect DEF fluid" shutdown in 250 miles error. Still working on getting ISTA running on an old laptop to run through the SCR test/diagnosis plan. |
07-06-2021, 05:07 PM | #19 |
14
Rep 132
Yeah, ok- got it. Sounds like the SCR tank system might be dosing correctly (or at least it thinks it is) and it's not seeing the expected NOx reduction. With your maintenance history maybe you can see if that "new to you sensor" can be coded if the test plan says it needs to be. I think you know this, already. I've read the SCR catalyst gets gunky and some people soak it in a solution. There are YouTubes about it. Gotta be careful not to etch off too much, though. Never done it, but I will try if I ever have to.
07-07-2021, 10:26 AM | #20 | |
522
Rep 629
I am guessing that while the truck was down for 16 months the DEF fluid expired... and/or the exhaust had water in it when it was off the truck and fouled the NOX sensors. Quite a bit of water poured out when remounting the exhaust system. Hope it didn't damage the SCR catalyst. That would suck. But only way to find out what is really complaining is to get ISTA running and go through the long test plan in the driveway. Edit: Carly will not force a regen due to the codes being constantly triggered. Maybe I'll have someone ride with me and keep clearing the codes. Carly might regen after that. From what I am reading this is a common problem after opening the system up and having the DPF cleaned. I guess the system just gets out of whack regarding before vs. after readings on the NOX and the system gets confused. Last edited by crystalworks; 07-07-2021 at 10:42 AM.. |
