01-09-2021, 05:06 AM | #2 |
1930
Rep 869
If they are small, I use a leaf blower and they come right out.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
00SH4WN84.50 Pauldunlop13425.00 |
01-09-2021, 07:20 AM | #3 |
1618
Rep 2,161
If you ever remove the bumper for a project you can drop the oil cooler bit and actually get everything out. The leaves are only what's visibly stuck...I took out a large dustpan of rocks, leaves, and debris and then cleaned off the fins with air. There was way more junk than I had anticipated!
01-09-2021, 05:56 PM | #4 | |
1082
Rep 890
https://youtube.com/user/Jbonly21
01-09-2021, 06:01 PM | #5 |
3274
Rep 6,723
You don’t need to remove the entire bumper... you will need to jack up the front end and loosen the bolts to the cooler from under car.
Wear glasses!!! There’s a lot of crap down there I bet. |
dms-011134.00 papasmurf_m3454.50 |
01-09-2021, 06:42 PM | #6 |
3633
Rep 1,397
My car was originally purchased by a certain celebrity living in Malibu. I imagine his long and expensive driveway was a billion tiny pebbles because that’s what I found in mine along with leaves.
Regardless, going under is the move. I had to pull mine out to do my CBC and it takes all of 15 minutes this way. There a few bolts to undo but overall you can let it hang down and blow air through or whatever you need to do. |
01-10-2021, 02:54 PM | #7 |
87
Rep 149
I use this claw to grab the big leaves.
https://www.amazon.com/gp/product/B00275F5I8 To remove the small bits, I use a shop vacuum with a long polycarbonate tube attached. Works quite well but not as effective as going under and removing the tray. |
Bernina539.50 |
01-10-2021, 08:25 PM | #8 |
/M Enthusiast
1599
Rep 1,619
I created a small suction hose that I attach to a shop vac to suck them out.
2019 M2 Comp, Alpine White, DCT, track car build, 1/2 cage, AP Racing Brakes & Nitron Coilovers, BM3 Stage 1 93 Oct.
2018 Porsche Cayman GTS, Night Blue Metalic, PDK, COBB tuned 93 Oct. 2004 Audi A4 Avant USP 6mt, RS4 clutch, built motor, Garrett GT3071r "Big Ass Turbo" Motoza Tune |
01-20-2021, 10:28 AM | #9 | |
318
Rep 746
02-02-2021, 11:49 AM | #10 |
1094
Rep 920
Consider investing in fine mesh grill covers from zunsport. They will filter out larger debris such as track rubber.
https://www.zunsport.com/us/bmw-us/b...ront-grill-set |
02-08-2021, 01:30 PM | #11 |
235
Rep 200
I asked the same question a few years ago and someone mentioned this kit on Amazon.com
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 It works great for reaching inside the front vents to get rid of all the small leaves, bees, bugs and other things that you want removed and it only takes a matter of mintues. MB |
02-08-2021, 02:08 PM | #12 |
2078
Rep 1,780
This it's super easy! 3 bolts for the oil cooler after removing the pan guard.
02-28-2021, 12:27 PM | #13 | |
1134
Rep 830
What I did find interesting is I paid $1700 to replace that oil cooler on a previous F80 and it to get it off is cake so wondering ho much of that $1700 was parts and how much was labor. |
02-28-2021, 03:53 PM | #14 |
3274
Rep 6,723
The OE and aftermarket oil coolers are about $500-600 so.... add the cost of an oil change, the rest would be labor unless more parts were replaced like hoses and such but, yeah you probably got shafted but at least now you know how easy it is.
03-01-2021, 10:54 AM | #15 |
1134
Rep 830
I was wrong, it was actually the radiator that I had replaced which obviously requires more work. Not sure why I thought it was the oil cooler.
03-05-2021, 08:21 AM | #17 |
1134
Rep 830
03-05-2021, 05:49 PM | #18 |
7602
Rep 3,604
I took mine apart when I installed my CBC - there's a lot of shit up in between the radiators than you won't be able to clean out without pulling them out of position.
DIY here that might be helpful for taking things apart: https://f80.bimmerpost.com/forums/sh....php?t=1594892
Current: F80
Prior: F82, F32 |
03-06-2021, 06:31 AM | #19 |
1836
Rep 4,203
When I dropped mine this is what fell out.... and there was more on round 2 cleaning. Car cane from Salt Lake City Utah. There is still so much gravel stuck in the cooler I might change it if I get any hi temp faults this summer
dms-011134.00 |
03-06-2021, 06:46 AM | #20 |
3633
Rep 1,397
Same amount of crap here, former celebrity/Cali car.
dms-011134.00 ellipsis2121617.50 |
03-06-2021, 07:17 AM | #21 |
13523
Rep 8,165
Do I know the celebrity? How much did you pay for the provenance?
And thanks for the thread, had no idea so much dirt accumulates in this area.
