07-27-2020, 12:44 PM | #1 |
Rep 84
Hard Water Stain Remover
Hi, I have hard water stains on my pearl white F80...
What's the best HW StubborStain Remover that I should go for... Also, to maintain the CB Roof ... what do you guys use to keep it in shape? Thanks!!!! |
07-27-2020, 04:50 PM | #2 |
538
Rep 1,047
If the stains are bad, you'll most likely need to compound them out. I'm not as much of an expert as others on here most likely, but depending on severity, it could be a very challenging job.
07-27-2020, 05:08 PM | #3 |
288
Rep 343
My hard water stains were pretty bad and had etched the clear coat. Soaking in straight vinegar wasn't enough to get them out. By hand, using Meguiar's Scratch-x and then ultimate compound on the worst areas was necessary. I did this by hand and had to apply using a cotton shirt to get enough leverage to get the stains out. It would be best done with a dual action polisher if you have experience using one.
07-27-2020, 05:25 PM | #4 |
36
Rep 62
Depends on the type of water spots you have. Some will wash right off and others will require some compounding to remove. The longer they sit the more damage it may do. Reason for compounding is over time it'll etch the paint so you'll have to level the clear coat.
Edit: I don't do anything special for the roof. When I took delivery I just took my DA to it to remove swirls (Carbon roof) ceramic coated it and then used a topper. I use a silica based spray after my washes to help protect the coatings and does what I need it to do. Garaging the car is always a plus. |
09-02-2020, 09:23 AM | #7 |
Rep 1
is this also water spot "damage"?
Hello Guys,
I am new in this forum and have been reading quite a bit on removing water spots. I have a question: If you see in the attached image my car has a water drip stain under the side mirrors. Is this also a type of "water spot"? And does the usual methods to remove water spot work in this case? I am not sure which compound I should get. Thanks! |
09-02-2020, 06:34 PM | #8 |
251
Rep 631
Drives: 2014 M6 Grand Coupe CP
You can try (white) vinegar or lemon juice. try a small spot at the bottom before doing the top part. I do not know what the commercial products are available for this although I am sure they are out there.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
10-03-2020, 03:36 AM | #9 |
12
Rep 89
You will not believe with the results. I tried so many things to remove them out of my white M4 nothings work until I found this product
https://sudfactory.com/shop/dissolve...-spot-remover/ |
