05-06-2020, 04:27 PM | #1 |
4998
Rep 6,863
Best DIY Ceramic coating for a complete amateur?
I would love to apply a coating to my car to maintain that freshly washed look - but I have little to no proper detailing experience. Is there a ceramic coating out there that is super easy to apply and nearly impossible to mess up?
05-06-2020, 05:39 PM | #2 |
136
Rep 453
I used McKee's paint coating last year and it was a breeze to put on. They seem to have another version out this year called "Ceramic Coating" and to be honest I'm not sure what the difference are. The old version called "Paint Coating" still seems to be sold though. It was very easy to apply. Spray on, wait 30 seconds, buff off. Water still beads perfectly and power spraying water gets most of the dirt off. Foam up and light swipe cleans everything else off.
icegrill2078.00 |
05-06-2020, 07:08 PM | #4 | |
2078
Rep 1,780
danchee136.00 |
05-07-2020, 08:49 AM | #6 |
298
Rep 798
Watch some videos and buy any of the above. Also read some reviews on autogeek. They have a lot of options.
One note - prep is key in coating application. Is your paint in good shape? If it’s all swirled/scratched up, the coating will accentuate the scratches. Also, you need to make sure the paint is super clean, so you’ll need a prep wipe as well, like Carpro Eraser. |
05-07-2020, 09:10 AM | #7 |
52
Rep 108
05-07-2020, 10:27 AM | #8 |
4998
Rep 6,863
Thanks for the advice guys. Yea I am looking for as little prep work as possible too. I can do a detailed wash and clay but I don't have a DA and wasn't planning to do a paint correction or anything. Paint is in good condition overall. Of course there are a few swirls but not huge spider webs or anything. I don't need the paint looking 100% flawless, I'm really just looking to capture that freshly washed look for longer periods of time.
05-07-2020, 10:33 AM | #9 | |
1234
Rep 1,164
05-07-2020, 02:29 PM | #11 | |
13524
Rep 8,165
Ideally, before applying ANY kind of paint protection, you need to prep the paint by decontaminating it (iron & tar spray removers, clay bar which usually jacks up the paint) and polish of because of the said damage that happens when you're mechanically removing gunk embedded on the paint. Now, issue with some coatings that are on the market now is that once you put a layer or two on, it can be very difficult to take off as they essentially lock the paint because they're so hard. So, when you run into some issues, e.g. during application or later in the future etched bird shit, water spots, etc., you'll have to do the process of decontamination and possibly light polishing all over AGAIN. It's a bit of a slippery slope. And you cannot keep buffing the paint forever or else you'll have no paint no mo'. Also, there's a bit of a misconception that ceramic/glass coatings do not need any kind of maintenance... you still gotta take care of it, by using drying aids, spray detailers or products meant for "refreshing" the coating. That way, you're adding incremental layers upon layers of extra protection on top of the "main" couple of layers of whatever paint protection product you've put on there in the first place.
Daveneezy109.50 ellipsis2121617.50 |
05-07-2020, 02:37 PM | #12 |
110
Rep 189
A good friend of mine is a Detailer and I've learned a ton from him. There's no doubt that ceramic coatings are the real deal. I have had 2 cars coated over the last few years and the cost was definitely worth it. But if you want something that you can do yourself, don't want to break the bank and it being worth it... then use C2v3 by gtechniq. I use this as a boost for my coatings, I apply it at least twice a year and it makes a huge difference. I recently leased a new tacoma and didn't want to spend the money coating it, so I used c2v3. I did a wash, clay, ipa wipe down, then hit it with C2v3 about a month ago.
This is the truck this morning: |
05-07-2020, 04:56 PM | #14 | |
136
Rep 453
My process took a day to do. Iron remover, wash, clay using N-914 as lube, coating prep wash, N-914 as drying lube, then move car into dark garage to cool the paint. Clean with N-914 and dry each panel as I apply the coating to avoid dusts on paint. I would say it took about 6 hours total. Then let it sit overnight and apply second coat the same way as the first. I only did 2 coats, and the spray bottle has enough left over to do at least 2 more cars with 2 coats. Very good deal for sure. |
05-10-2020, 08:33 PM | #16 |
BimmerPost Supporting Vendor
1998
Rep 6,916
probably the easiest go to ceramic coating to user with little to no experience would be Fictech One - 1 year ceramic coating -
1. make sure your paint is clean and as good as you like, meaning if you feel it needs swirl removal, remove them and prepare the paint. 2. spritz fictech one on the paint and buff off. 3. enjoy! Fictech One It will last up to 1 year with proper maintenance. |
05-10-2020, 09:48 PM | #17 |
478
Rep 591
wow great product!
2018 F80 M3 6MT///Black Sapphire w/ Sakhir Orange Leather
2006 S2000 AP2 Laguna Blue Pearl 6MT |
05-10-2020, 11:03 PM | #18 | |
136
Rep 453
07-07-2020, 04:00 PM | #19 | ||
779
Rep 1,636
Used this on my BSM m4 with no ceramic coat and the paint looks cleaner for longer no question. Also easier to dry after a quick wash. Don't use too much though because it can streak. |
07-16-2020, 09:44 AM | #20 |
664
Rep 364
Drives: 2019 F90 M5 Comp
I used Proje' Car Care and it was my first time coating any car. It came out well for me.
19" BMW F90 M5 Comp
Utku Noa 93 Tune: 700hp/680tq Check out my Socials: https://solo.to/whatsyourforte |
08-12-2020, 09:40 PM | #21 |
306
Rep 344
Curious if this method is okay to do on a car that has a lot of PPF & non PPF'd panels are in great shape. I have a 2018, so pretty new car.
1. Wash 2. Clay with light bar 3. Wash 4. Ceramic wax x 2 5. Spray wax Am I really missing any steps in between 2 & 3 that are "mandatory"? |
08-12-2020, 10:15 PM | #22 | |
977
Rep 1,704
Drives: 22 X3MC MBB - C-17 Globemaster
no but you could possibly decontaminate the iron and other things with another substrate, claybar gets most but you need another chemical to remove harden chemicals. |
