03-24-2020, 11:31 AM | #1 |
177
Rep 267
Drives: 2006 Z4 M Roadster
Routine O2 oxygen sensor replacement?
I was reading through the service manual last night and saw that BMW recommends that the O2 sensors be replaced every 100K miles in order to maintain emissions performance and improved gas mileage.
My car is at 219K and they have never been replaced. No codes. Just passed emissions and safety in January. I also tend to average about 23mpg commuter mileage (mix of highway speed and stop and go). Pure highway mileage is 31-32 mpg. Just wondering if you folks with higher mileage cars change the sensors as a matter of routine per the BMW recommendation. Thoughts or experiences? |
03-25-2020, 12:12 AM | #2 | |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
03-25-2020, 07:45 AM | #3 |
177
Rep 267
Thanks pokey. I’ll add this to my maintenance list.
03-25-2020, 08:43 AM | #4 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
What pokey said, my car was running like shit for a little while before the actual CEL appeared for o2’s. Even the rear o2’s affect fuel trim levels slightly I believe, which is why so many folks who run catless without tunes sometimes report rough idling.
03-25-2020, 12:03 PM | #5 | |
479
Rep 2,782
I haven't confirmed whether some of the older models with narrowband sensors use rear O2 control, but I wouldn't be surprised. It's certainly possible to delete it with a tune. The MS45 and MSS70 ECUs both have options to enable "self learning" with 4 O2 sensors (2 per bank), or reduce all the way down to a single O2 sensor for 6-1 setups (not sure if this works since no one has tried it to my knowledge). To figure out what "self learning" means would require digging into the ECU further than I have gone *ahem* terra *ahem*
