02-10-2020, 12:15 PM | #1 |
dances with roads
4732
Rep 4,096
Installing shifter -- and a whole lot more
EDIT: I began this thread asking for advice about what else I should do while I have several big bits pulled off the underside of my car. It's turned into one of those ever-expanding projects so I've changed the thread title. Here are the bits I replaced.
------------------------------------- My Z4MC has about 83K miles. It's had regular maintenance throughout its life including transmission and differential oil changes. I have all the bits pulled off underneath so that I can install a short shift assembly, RE X-pipe, and RE transmission mounts. The driveshaft differential seal is also seeping so I plan to drop the driveshaft and deal with that. Oh and I'm not thrilled with the clutch operation and bleeding didn't change anything, so I may pull the gearbox out. (EDIT: I did.) DRIVESHAFT - driveshaft guibo - driveshaft center bearing - new hardware as indicated by newtis.info REAR DIFF - input shaft seal - oil change using BMW gear oil CLUTCH - OEM or equivalent disc, pressure plate, T/O bearing, pilot bearing - OEM equivalent dual mass flywheel - all new hydraulics - SS flex line (overkill maybe but it came in the kit) - new hardware as indicated by newtis.info SHIFTER - Auto Solutions short shift kit (I used the blue bushings) - OEM rear shift rail mount - OEM transmission mounts WHAT ELSE - Vibra-Technics motor mounts (road version) - new bolts for aluminum reinforcement plate under engine - new bolts for steel reinforcement plate under center of car Last edited by wdb; 05-23-2020 at 11:02 AM.. |
02-11-2020, 12:43 PM | #2 |
160
Rep 224
If you're not happy with the clutch action then you may consider removing entirely or installing a modified clutch delay valve. There's plenty of data online already if you search. As for clutch bleeding I typically fill a 60cc syringe and "push" the fluid back up towards the reservoir (make sure there's room in the reservoir.) Getting air in the clutch lines or cylinder is easy using the old school method.
At 83k I really don't think you're in need of a lot of stuff, obviously address the leak and possibly just install a new flex disc because they're cheap, reuse the bolts. I'm not even sure a new clutch is necessary at this point, and if you choose to install one I wouldn't do the flywheel; (typically the flywheel is a 2:1 replacement interval with clutch)
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
wdb4732.00 |
02-11-2020, 01:26 PM | #3 |
286
Rep 679
I would check the engine mount bolts/brackets while under there.. As well I have super low mileage car but I find stock clutch the best of anything Ive driven. Not too heavy and perfect bite 1/2 way off the floor.Dont think you need aftermarket- probably worn with that mileage.
02-11-2020, 02:59 PM | #4 |
2429
Rep 2,704
Drives: Built not Bought 04 Z4 VF
Not sure if the M is a 2 piece DS, but if it is look at the centre hanger bearing and the slip joint bearing. Not expensive parts.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
02-11-2020, 04:47 PM | #5 | ||
dances with roads
4732
Rep 4,096
It is a 2-piece driveshaft. I call that center bearing thing a guibo and I'm planning on putting in a new one. I'll look into the slip joint bearing, thanks. Any thoughts on the rubber donuts on the ends of the driveshaft? |
02-11-2020, 05:53 PM | #6 |
2429
Rep 2,704
The guibo is the flex joint between DS and tranny output
02-14-2020, 08:05 AM | #7 |
286
Rep 679
Its GUIBO. GUIDO WAS ON SAT NIGHT LIVE YEARS AGO LOL
filtercoffee106.00 |
02-14-2020, 03:54 PM | #8 |
dances with roads
4732
Rep 4,096
I decided to go ahead with pulling the gearbox. Transmission jack ordered; I'm too old to be playing around with anything else under there.
02-15-2020, 03:01 PM | #9 |
2429
Rep 2,704
Thanks. Fixed.
Your cap lock is busted👌
wdb4732.00 |
02-21-2020, 02:54 PM | #10 | ||
dances with roads
4732
Rep 4,096
As I mention in the now-edited first post, this is becoming something of an omnibus project. I've been following the excellent Pelican Parts how-to and it says, among other things, "remove the starter -- but first get the intake plenum out of your way." So I dutifully follow *that* how-to, pull the plenum off, and, lo and behold....
You're right, it is, my bad. I'm still looking for information on longevity. I'd imagine it to be pretty robust, but then again it's German rubber. Quote:
Does anyone want to buy most of a brand new 1/2 ton transmission jack? As I now know, removing the intake plenum means destroying 6 single use clamps. Do I replace them with same, which requires buying a special tool, or do I source some hose clamps of similar dimension? I'm going with the latter but open to hearing others' experience. I figure I may as well also do the transmission and rear fluids while this is all going on. My parts list is growing longer and longer! |
02-22-2020, 12:34 PM | #11 |
2429
Rep 2,704
The guiBo takes a lot of abuse so as a relatively cheap bit I would replace seeing as its easily accessible now.
wdb4732.00 |
02-25-2020, 07:34 PM | #12 |
Down Under!!
1621
Rep 4,294
Great to see your doing it yourself mate. Those intake ring clips can be re-used if your not ham fisted with them. Getting them back on is not a nice job, just a heads up for ya.
filtercoffee106.00 wdb4732.00 |
02-26-2020, 04:52 PM | #13 |
dances with roads
4732
Rep 4,096
I found some narrow hose clamps used on Porsches that I hope will fit nicely. Cheaper than buying the tool I'd need even to re-use the BMW items. I'll let folks know how well they work.
03-08-2020, 09:50 AM | #15 |
dances with roads
4732
Rep 4,096
The !@#$%^&* transmission is out, finally. What a trip.
First was the jack debacle. They sent me a jack, the packaging of which was destroyed in transit and therefore crucial bits were missing. I cussed and moaned and Amazon finally offered to send me an entire new jack free of charge! Sounds nice right? Except it took forever and day to arrive, and of course the packaging had not survived and there were missing parts. At least I had enough between the two packages to assemble one complete jack, except for a couple of common items I got from my local Ace store. Finally I can finish pulling the gearbox. I get the jack situated and pull the remaining bolts, and start to pull the transmission back. It comes away a certain amount then stops. What is going on? After a lot of effort and prying and grunting, I see what appears to be a spot where it is failing to separate from a thin plate that goes between the block and bell housing. It turns out that, despite having two different sets of instructions to follow, neither of them told me about a little bolt that goes through from the engine side, through the thin plate, and into the bell housing. I had to pull the front suspension support plate down to get at it. Finally got it removed, hurrah! I look back at the jack which I assumed had been faithfully supporting the gearbox all this time. It wasn't. It loses hydraulic pressure, all by itself. Lovely. But at least it got the beastie out from under the car. After that I was pretty beat so I left everything for the night. I'm heading back out today to see what I've uncovered, and how much of a mess I made of that thin plate. Moral of story: believe your eyes, not the instructions. And take everything off that even remotely might be blocking your view. A few bucks on one-time use bolts is worth to have a good look. |
03-19-2020, 04:46 PM | #16 |
dances with roads
4732
Rep 4,096
Parts!
Center bearing (already installed), guiBo, transmission mounts. I also have Rogue transmission mounts but I think I'm going to stay with stock for this location. Auto Solutions shifter goodness! Shift lever and bushings in the arm and ready for installation. Clutch kit, flywheel, various other bits. Vibra-Technics motor mounts, road version. I checked the mount bracket - to - engine block bolts, which have been noted as a problem spot on these cars. They were all nice, tight and snugged up. Either they were done before or the car was not among those that had the problem. Either way, if they are tight at 83K miles I don't think I need to worry about them. Rear diff oil change kit. This is not strictly necessary but I replaced the input pinion seal, plus the previous owner had used Redline oil and I wanted to go back to BMW OEM. Never had any issues with the Redline for what it's worth. Last edited by wdb; 04-20-2020 at 10:21 AM.. |
03-21-2020, 09:40 AM | #19 |
dances with roads
4732
Rep 4,096
03-22-2020, 05:02 PM | #20 |
dances with roads
4732
Rep 4,096
Okay! New flywheel is in, new throwout bearing is in, new clutch is in. I bolted the pressure plate down tight before removing the SAC lock thingamabob; hope that was the right thing to do. Pelican Parts doesn't seem to think so in their how-to but they had some other stuff wrong. And Efthreeoh has an excellent writeup on N52 clutch replacement that says to bolt it down tight before removing the SAC thingamabob (throwing star?).
Only had to invent two "BMW special tools". The hardest part was probably needing a bolt about 3/4" longer than any I had laying around. This meant going to a hardware store, which of course these days meant risking one's life. Fun times. |
Efthreeoh17315.00 |
03-23-2020, 09:31 AM | #22 |
11414
Rep 1,795
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Least favorite job for me is offering up the transmission, getting it inserted, holding in place as the bolts are started. I know you bought the transmission jack, but this is a time that I've always appreciated an extra set of hands...but with social distancing, do we assume you're doing this alone?
wdb4732.00 |
