01-22-2020, 09:29 PM | #1 |
20
Rep 78
1F2102 Drivetrain Malfunction BPM to BM3
2015 F80 6MT
For the last 40,000 miles car has had BPMSport tune, AA MP and SSR Intakes. I decided to switch to BM3 so I could add VRSF DP and CP and have control over my car. I downloaded the BM3 Software, picked a Stage 2 93 octane OTS map and flashed it. Instantly received Drivetrain Malfunction and have no power. Car drove perfectly fine before this flash. Other strangeness. My sports display did show 560/560 now its 640/560. My car now starts with GTS roar but with flaps closed. Even when in Sport+ they stay closed until the car has ran for a few minutes. Car idles very rough for 20 seconds or so and acts like it is going to die. Some strange noises in the exhaust as well guessing it's flappers vibrating. Dzenan Becic from BM3 support has been great so far but I'm past 24 hours without a car and thought I'd check to see if anyone else knows a solution. So far BM3 has told me to flash to stock. Apparently flashing to stock isnt flashing to "REAL STOCK" as they say in this post below. On Bimmerpost this issue has apparently been very common and the only fix is for BM3 to remote into my car and do some manual coding. People have tried to flash from VF tuning, Hex and others, to BM3 and everyone gets this code. 1F2102 https://f80.bimmerpost.com/forums/sh....php?t=1620779[IMG][/IMG]
///M3 2015 F80 6MT Moonstone Metallic
- 8 UR V8 - www.AppalachianDrive.Club |
01-23-2020, 01:40 PM | #2 |
163
Rep 387
Some other tunes basically change the type of your car to identify as something else, like a GTS for example. You most likely need to use the original tuner to flash back to stock.
BM3's stock file is the stock file for whatever your car identifies as. If your car is identifying as GTS, it will flash a stock GTS file. You probably have a drivetrain malfunction and no power because you don't have the FSC code for GTS and/or the water injection system. After returning to real stock, BM3 should be able to reset your account and you can sign up again, where it will detect your car correctly this time. |
01-23-2020, 01:43 PM | #3 | |
20
Rep 78
They wanted 250 to transfer the software license to me, more money to send me the tune and stock map for my car. More money to edit it. That's why I switched to BM3. Update. I'm home now and connected to the car. BM3 is removing in to fix. I'll keep ya posted.
behindthen0thing839.50 |
01-23-2020, 03:07 PM | #4 |
BimmerPost Supporting Vendor
8271
Rep 18,856
Drives: BMW
Found this is the norm on VF-flashed cars going to BM3.
We have to flash the stock file beforehand (outside of BM3 portal) to fully return to stock, as the DMEs were identifying as GTS.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
RElias21570.00 |
01-24-2020, 07:04 PM | #5 | |
20
Rep 78
I wouldn't know where to start to get back to stock. But!! BM3 remoted in and did it. Now everything works great. Shout out to Serge.
08-31-2020, 12:31 AM | #6 | ||
82
Rep 311
08-31-2020, 06:58 PM | #7 |
5508
Rep 5,187
As long as you flashed BPM back to stock before using BM3 you should be good. Disconnect the negative battery cable for 5min and check again. If still a problem reinstall the tune again. Try that.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
12-12-2022, 12:48 PM | #8 |
Rep 3
I had the exact same issue last week. I didn't know the car (2016 BMW F80) was flashed with a BPM Sport tune. Bought the car from a BMW dealership back in May of this year. Purchase BootMod stg 1 and noticed my gear indicators were not showing any I had no rev match settings in the tune. My oil level said low as well. Car drove like crap with no boost. When I flashed back to the stock tune it went into limp mode with the error 1F2102
All other OTS maps flashed had no codes but drove like crap. Worked with BootMod Support and they remoted into my PC with the files they sent me to download and fixed everything. Great Service!!! |
