01-20-2020, 01:48 PM | #1 |
13
Rep 45
OEM M Lip no lining up ???
01-20-2020, 02:40 PM | #2 |
3274
Rep 6,723
Yeah. Loosen the bottom bolts and get it snapped in properly before you cinch them down.
I had a similar issue when I did mine but wasn’t as bad as yours. Also assuming you trimmed the lower plastic pieces per the instructions? |
01-20-2020, 05:22 PM | #4 | |
3274
Rep 6,723
The lip mounts to the insert piece, which mounts to the bumper and splitters. There should be a slight gap between the ends of the insert and the splitters that the lip clicks into place with. |
01-20-2020, 05:24 PM | #5 |
3274
Rep 6,723
Also the lip mounts without splitters and will follow the contour of your bumper. I’d recheck the install compared to the actual instructions and mounting hardware.
01-21-2020, 08:08 AM | #6 | |
13
Rep 45
I'm being told the aftermarket splitters will not line up compared to the OEM ones which are apparently more aggressive. My current splitters are only held on by the 3m tape - there is no bolt or screw for these |
01-21-2020, 09:34 AM | #7 |
3274
Rep 6,723
The oem splitters are the same. The lip has the instructions on how to mount with the splitter which I’m assuming you either don’t have or didn’t read.
01-21-2020, 10:50 AM | #8 | |
13
Rep 45
https://f80.bimmerpost.com/forums/sh....php?t=1592862 |
01-21-2020, 12:15 PM | #9 | ||||
6580
Rep 5,304
This is fact. The OP has the "other" version; the one that fits snug to the bumper. |
01-21-2020, 01:07 PM | #10 | |
3274
Rep 6,723
I have no prior experience with aftermarket splitters with the oem lip so I was just using a logical guess. I guess my thinking was flawed. |
01-21-2020, 03:42 PM | #11 | |
13
Rep 45
https://f80.bimmerpost.com/forums/sh....php?t=1273925 |
01-21-2020, 03:45 PM | #12 | ||
4925
Rep 3,806
There are people who installed the lip without the OEM splitters, and results vary, but regardless that's a custom job. |
01-21-2020, 04:35 PM | #13 | |
3274
Rep 6,723
Either way. Guess doesn’t work with aftermarket splitters. YMMV. https://f80.bimmerpost.com/forums/showthread.php?t=1586356 |
01-21-2020, 04:38 PM | #14 | ||
4925
Rep 3,806
01-21-2020, 05:37 PM | #15 |
3274
Rep 6,723
