01-17-2020, 06:37 AM | #1 |
506
Rep 1,385
Properstyle's Carbon roof E90M
Please like and subscribe.
So I guess one could say I am a bit behind with making a journal on this car, I've had it for going on 2 years now next month and so far it's been great with its small share of downs. I decided I would start Vbloging the builds as I've found its often easier for me to speak off the cut about a car instead of getting lost in thought trying to write down everything I am thinking in regards to passion for cars. My point of doing this Channel is to be transparent about everything. Something I've found with the E9x platform seems to be lot of close held knowledge instead of putting it out there for others maybe more less caring that are willing to push the envelope to see more. The car has reach a price point stability where it is now cheap enough that younger buyers who are power hungry to see or reach a limit. A big reason imo the f8x market has taken off is the willingness of companies to working together in healthy competition to be first to milestone and customers willing being open about what they have done to their car to reach point a or b. So i plan to do the same. I Purchased the car from micheal who purchased it from the original owner Justin out of Oklahoma. The car happens to be 1 of the few cars IND produced a carbon fiber roof for, since the sedan was never optioned for such. The car was located in Maryland with 72k miles on the original rod bearings, Car was still NA but had some nice tasteful mods such as a Stop tech tropy kit front and rear, along with a set of AST 5300s which I replaced for CLub sports to achieve the height I wanted out of the car. Car was on stock comp wheel that were removed for a set of F14 super deep concave 19x10s, 19x11s. The exhaust was stock that I replaced with a catless Active auto Gen 2 from the header back. This was my 3rd E90m at this point and honestly after having one being supercharged I could never see my self driving a NA one again and be happy. While I believed the car had been well maintained I still choose to do the rod bearings just for pc of mind before installing a Ess 625kit blower. Rod bearing were replaced with a set of BE units with Arp bolts. I made contact with mike at BPM and purchased a tune for this car using the large Bosch green injectors for my blower kit combined wit a 3.6in pulley. On a 93 octane tune the car produced 565whp on a dyno jet after 3 runs. after being relocated to killeen texas for work, I drove the car out to AZ for training where I continued to enjoy the car for 3 months, after returning back to Tx I finaly got to attend the Dallas wanna go fast Half mile where the car managed to run an averge of 154mph from a true dead stock 1/2 mile run. I attended this even after making another pulley swap to a 3.48. the car performed well and drove there and back with no hiccups. The following year I purchased a set of bosch 123 injectors (600cc injector) and purchased a reflash from bpm. The weather was starting ot finally warm up some so I attended a Sunday test and tune at littler river raceway, The track prep was not the greatness and with no way to drive around the water box it was tough to put down any power off the line. My second pass of the day with a 3400rpm launch the put down the fastest E90M 1/4 time of 10.9 at 127.7 for a stock motor in 2800 DA. What made this pass important to me was doing it with Full interior with no parts removed, 1/2 of gas and on 295/30/19s. While it is clear I could have gone much faster reducing weight or running 18s my goal with the car was to run a time in daily driven status. alot of changes have sense been made and I full intent on going bottom tens when everything is full dialed in.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car Last edited by Properstyle; 06-25-2020 at 10:27 AM.. |
01-17-2020, 06:54 AM | #2 |
506
Rep 1,385
Slip and photos
Here are a list of the parts/mods that I've done... Enjoy! Engine: ESS 625 Kit - 3.48 Pulley- Bosch 123 injectors (610CC) installed by me 2.CSF M3 Engine Oil Cooler Engine Management •BPMSport Blower tune- BMW E9x M3 - 2007-2013 - Purchased from Mike@BPMSport - Tune Includes:1.BPM Sport Launch Assist - Enabled: 4000 RPM 2.Reprogrammed ignition timing, & optimization of fuel quality: 93 Octane 3.Remove Top Speed Limiter 4.Servotronic Steering Changes 5.650kit boost level tune on larger injectors 6.Calibrated for Catless Mid pipe Engine Misc• Exhaust•active Auto Werke Gen 1 --installed by me • active auto Werke Gen 1 rear section -installed by me BE Rod Bearing- APR Bolts- installed by me Fuel System Bosch 123 Injectors Motor Build Oil Systems Drivetrain:• Braking:• STop Tech ST Trophy Kit front and rear •Stoptech Stainless Brake lines - front and rear Suspension/Chassis Bracing:•22839BW KW CLub Sports With Eibach Springs (clearance) Bimmer world cenfircal bearing sway bar endlinks Exterior:•eBay E90 M3 OEM-Style Trunk Lip Spoiler - Purchased from eBay - Clear Bra'd at Elevated Auto - Ceramic Coated by Elevated Auto - Installed at Total Motor Werkes •IND Carbon Fiber Roof- Installed by IND •MOD Carbon CRT Trunk Wing Matching carbon fiber weave Interior:•IND Custom Piano Black Painted trim To contrast extended Fox Red Interior •Awron Kompressor Gauge SNow Performance Stage 2 Boost cooler gauge Wheels/Tires: Daily Setup/Track:•Toyo R888R 295/30/19 • Forge Star F14 19x10 et 15 Front- 19x11 et 25 rear- Custom Powder Coat gunmetal grey with blue hue Show Setup:•Lexani 255/30/19 Front- 275/30/19 Achilis •ACS Type 2 3PC 19X10 Et 9 front - 19x11 ET 3 Rear Electronics/Lighting LUX Angel EYE pure white non adjustable Restoration Parts:
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car Last edited by Properstyle; 06-25-2020 at 10:45 AM.. |
01-17-2020, 10:41 AM | #3 |
20
Rep 83
Fellow carbon roof E90 checking in! I believe mine is a 1 of 2 piece from Vorsteiner, and what's interesting is that it has a cutout for the sunroof...
01-17-2020, 11:24 AM | #4 |
3085
Rep 2,747
10 second sedan... nice
9ers
Drifter2090909.50 |
01-17-2020, 12:12 PM | #5 |
910
Rep 2,091
Damn super clean car man!! Makes me wish I kept my AW E90 lol
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
01-17-2020, 08:36 PM | #6 |
6713
Rep 10,599
Would love a carbon roof one day. I just do have concerns about long term durability even though my E90 won't be my daily after the next year or two.
Your car looks immaculate! Very nice |
Properstyle506.00 Drifter2090909.50 |
01-17-2020, 10:49 PM | #7 | |
506
Rep 1,385
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
Blindside_1376712.50 Drifter2090909.50 |
01-18-2020, 09:08 AM | #10 |
506
Rep 1,385
I will be doing a vblog later next week on my fuel system and tune with me now being on E85
