11-12-2019, 03:57 PM | #1 |
157
Rep 1,107
Dark Fluid in Reservoir
2007 M with 80K miles. I'm a religious full brake/clutch fluid flusher every two years. I'm due for a flush and noticed for the first time that my fluid is dark. I've never flushed the ABS system, only done standard flushes.
Brakes and clutch feels fine. Thoughts on what might be going on? I no longer have an INPA setup PC, to do an ABS flush. Thinking I'll give it to my mechanic to do a full flush including ABS and then watch the brake fluid. If it goes dark then I've got some master cylinder (or clutch cylinder) seal aging. Has anyone been through this before? Thanks in advance. |
11-13-2019, 07:04 AM | #2 |
222
Rep 375
Done any hard braking recently...or more hard than usual that could have caused overheating? Is the fluid at the correct height, any sign of leaks?
11-13-2019, 12:40 PM | #3 |
157
Rep 1,107
No particularly hard braking events that I can recall. Fluid level looks good and I don't see any signs of leaks (though I haven't looked very closely around the master cylinder).
One blip is that around a year+ ago I was experiencing a "hitch" sort of feeling in the clutch movement when the car was cold. It went away quickly once I started driving and things began to warm up. I bought a new clutch slave and master cylinder in preparation to swap those out...then the hitch cleared up after a few months. Maybe I'll try and get INPA running on a laptop again and do a full (with ABS) flush myself and then monitor the fluid...or have my indy do it. |
11-13-2019, 09:42 PM | #4 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
A picture might help. You can also use a moisture tester. Some brake fluid change color as moisture is absorbed, maybe there’s a corrosion somewhere along the line that is allowing water to be absorbed into the fluid.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
11-15-2019, 09:30 AM | #5 |
157
Rep 1,107
A moisture test is a good idea. That would confirm whether it was from moisture or as you say some contamination. I don't think a picture is going to help. The car is very clean, doesn't go out really in inclement whether (but still sees around 7K miles a year). Our heated seats are great!
I tapped a contact I know who has been a BMW master tech for 2 decades or so regarding the need to flush the ABS system as a maintenance routine. He basically said "no". Here is his response: "We dont normally bleed the abs module. The fluid goes from the frt and rear ports on the brake master through the abs module to the individual wheels. So it is getting flushed but there are some parts that won't be flushed as the valves are not being opened and closed unless they are activated thru the tester. You could go out and stomp on the brakes to activate the abs and then do your flush. I wouldn't worry about it. I have always done just regular flushes on all of my BMW's and never had a problem. That's what we do here at work" |
11-23-2019, 02:52 PM | #6 | |
General
17315
Rep 18,737
12-04-2019, 02:00 PM | #7 |
157
Rep 1,107
I happened to catch a live episode of MotorWeek a few days ago while I was eating lunch (never been a fan). Believe it or not "Goss" as in "Goss' Garage" is still at it and during his tech tips he was advising all the Impala owners out there to make sure that when their shop flushes their brake system every two years (he got that right) that they also flush the ABS pump system. Oh boy, so many opinions on this.
12-04-2019, 05:25 PM | #8 | |
66
Rep 247
12-13-2019, 10:12 AM | #9 |
160
Rep 224
I've done a hundred brake flushes over the years and always skipped the ABS pump. The key is to do the flushes frequently so there's never really old fluid anywhere in the system. You can do a flush and then do another in about a weeks time and that will likely get most of the old fluid out of the complete system. Be sure you're draining (sucking out) the old fluid from the reservoir prior to the bleeding process, this ensures a more complete flush.
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
